Old 04-07-2020, 07:59 PM   #1
dtkarst
Is this a correct 71,72 tilt?
Looking at buying this tilt column, steering wheel is correct not sure about the yellow bowtie, but can anyone tell me if this looks like the right column and what years it may have come from? Any help would be appreciated.
dtkarst is offline   Reply With Quote
Old 04-07-2020, 08:12 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Is this a correct 71,72 tilt?
It's a van tilt.
Jim
FirstOwner69 is offline   Reply With Quote
Old 04-07-2020, 08:26 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Is this a correct 71,72 tilt?
Bottom of it says it's a Van tilt. Truck tilt has a short shaft at the bottom of it.
This one I got from Randy 500 for the 68.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-07-2020, 08:44 PM   #4
70shortfleet
70shortfleet's Avatar
Some of the early ones did not have n/s switches
70shortfleet is offline   Reply With Quote
Old 04-07-2020, 08:52 PM   #5
dtkarst
They’re asking 150, is that worth picking up still?
Old 04-07-2020, 10:56 PM   #6
FirstOwner69
I've seen them sell here for that or a bit more. However, I've bought a total of 5 or 6 truck, van and motorhome tilts for $50 each at the local salvage yard. There are several threads on how to modify a van tilt to work in a truck.
Jim
Old 04-07-2020, 11:06 PM   #7
FirstOwner69
Here's a picture I've posted before showing the 3 types of original tilts that work in our trucks.
Top- RV (modification required)
MIddle- truck
Bottom- van (modification required)
Jim
Old 04-08-2020, 08:30 AM   #8
clay68c10
clay68c10's Avatar
Like the others have said, it is a van tilt. It would work fine, but there’s no neutral safety switch. So you will have to source one and mount it. Not a huge deal, but something to consider with the pricing of it.
If you can get it cheap, then I’d say go for it. Otherwise hit a junkyard and get an RV version.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 04-08-2020, 08:35 AM   #9
dtkarst
I’m not really needing one, I’ve got one in my 71, but I figured if it were the real deal truck tilt then I’d snatch it up for 150. I’d be crazy not to I think, but since it’s a can tilt that seems to change it. I appreciate the feedback though, learn something new everyday
