04-17-2020, 10:34 AM | #1 |
1968 4X4 rear leaf springs ?
Looking to replace my rear leaf spring on the 68 Burb does anybody have good leads on places to purchase? I'm looking for stock height as I installed rear flip kit mounts that raises the back by 4" to match my front leaf springs already installed.
Thanks in advance! Chad
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
04-17-2020, 05:15 PM | #2 |
Re: 1968 4X4 rear leaf springs ?
I don't know that much about springs but I was looking at these rear springs for my 68 GMC 4x4
1991-2002 C3500HD Lenght: 56" split in the middle at 28" Width: 3" Arch: 4-5/8" OEM: 15636134 MPN: 22-1009 While they look like they will physically fit, maybe someone with more knowledge could chime in |
04-19-2020, 09:14 AM | #3 |
If I remember correctly, 67-68 trucks have different size rear springs than the 69-72 trucks and are not an off the shelf solution.
Somebody like Eaton Detroit Spring could make you a set, that's where I would start. Otherwise, consider a spring swap. What is the width of your stock spring? If it is a 2 1/2" then a 56" spring from a square body truck (3/4 ton suburbans in the 80's had the longer spring. 1/2 tons usually had 52" spring) and relocating your rear hanger (again) to accommodate that length an option.
04-19-2020, 10:05 AM | #4 |
The 67-68 springs are about 3.25" at the eyes and they taper to 2.5" in the middle.
The pin is in the middle and they are about 56" long I also found that a 01 - 06 2500HD / 3500 rear spring hanger (flat style) could be made to work on 67-68. This hanger has the right spacing and allows the use of existing frame holes with room to drill the hanger A PO on my 68 GMC SWB 4x4 added a rear bumper using a generic bracket and butchered the rear spring hangers. I was looking to use those 1991-2002 C3500HD rear spring and the 01-06 3500 flat style hangers but found a set of 68 front and rear spring set with all the hangers on craigslist for a $100 and a 3 hr ride. |
04-19-2020, 01:21 PM | #5 |
Try Benz Spring or Oregon Auto Spring in Portland. One of them should be able to make you a new set.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
