![]() Join Date: Dec 2017
Help please, Rear drop shocks won’t stretch far enough
Hey guys, I’m needing some help here. I just put in a 71 rear end in my 64, I also installed 5 inch drop springs, 1.5” blocks, shock relocation brackets, and new shocks...Everything was going smooth until it was time to hook the bottom of the shock to the relocation bracket and it doesn’t stretch far enough. This kit came off of the 71 with the rear end so should all fit, only thing I added are the lowering blocks. It does look like I’m about 1.5” off. Could that be it and I need longer drop shocks or am I completely missing something?? I have read and watched thread after thread trying to find a solution, any help is greatly appreciated. I measured the shock extended at 13.5” if that helps.
Posted via Mobile Device Last edited by 64 rust; 04-19-2020 at 09:14 PM. |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Help please, Rear drop shocks won’t stretch far enough
The top of the shock is attached to the x-member/chassis. The bottom bracket moves with the rear end up or down.
Did you lift the rear end by itself?
#3 | |
Posted via Mobile Device Last edited by 64 rust; 04-20-2020 at 01:01 PM. |
![]() Join Date: Jan 2011
Set it on the ground and see what it looks like. The block you added wont change the shock length. You will need a 2 or 3 degree shim to get the pinion angle to where you need it.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#5 | |
Posted via Mobile Device |
I am about to be in the same boat. I completely overlooked shims!!! Never crossed my mind truly! Where are you purchasing them and what are you going to use? I’m doing a 4in spring and 2in block
#8 | |
Yeah , we’re in the same boat! Lol I have a 63 , that I’m currently building the 1971 GM12T , to put in it. So the issues you’re having unfortunately, are helping me. So I appreciate this a lot. I haven’t purchased shocks yet either . I’ll look into the shims. I have been leaning towards the No limit panhard bar.
Doesn't the bracket in your picture go on the top?
Moderator
Just a suggestion, dont purchase a shock until you have the truck on the ground with all the weight on it, pinion angle set etc.
Then measure the static height, not compressed or extended to determine the shocks you need. I read an inaccurate statement above on shock length that may cause someone to have to purchase another set of shocks once they purchase the wrong length the first (or second) time. Just sayin.
#13 | |
Moderator
Your 15 inches extended number may or may not be correct in that the total drop with wood installed etc. at a static stance is unknown as I understand it. Correct?
#15 | |
#16 |
So, not sure this is the same or different, but i ran into a very interesting issue dealing with shocks. I am install Bags, shock relocation's, adjustable rear trailing arm mounts and so on. I have c-Notched the frame and assumed that this means i need drop shocks, and if i am not mistaken, this is not necessarily true. i found after measuring that a set of beltech Street Performance shocks will work. They go from 12.5" to 19.5". Now i was shocked (no pun intended) to find that after measuring fully up and fully down how much "shock" i needed.
Again, not sure this helps..... |
#17 | |
#18 |
Did the upper brackets get put on backwards by mistake? forcing the top of the shock towards the front of the truck more?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#19 | |
#20 |
Moderator
Ya they say with 2" lowering blocks and the new lower shock mounts that 15''s are not a good thing.
#21 | |
#22 | |
That being said, lots of guys have used them & survived. Just be aware it is a safety issue.
#23 |
Yeah I am right below the line, I read all over 15 inch wheels were safe, I’m honestly not worried about it just going to run with 235/75/r15’s, it’s really close to the line just have to be careful
#24 |
It's only when there's no tire on the rim that it could dig in to the road surface ( w/a 1.5" block). Just getting a flat w/a tire still on the rim won't let it happen but you have to plan for worst case scenario so OTHERS on the road around you don't get hurt if it happens.
#25 |
Junior Member
![]() Join Date: Mar 2019
I had the exact same problem with CPP lowering shocks. I ordered the next size bigger and now they fit fine.
