Old 12-10-2003, 01:24 PM   #1
Suicide-D
Location: Katy, TX...but the love of my life resides in Dublin,OH.
Heater question
I have a weird situation going on. My heater blows cold air all the time. I have felt both heater hoses after the truck has gotten to operating temperature and they are hot but the heater air is barely warmer than outside air.
I have noticed leaves and pine needles blowing out of the heater duct. Is it possible for the leaves to have the heater core blocked and the air is moving around the core without getting heated? It feels like it blows fairly hard, just not warm.I am about to pull off the heater box but that is such a pain in the arse.
I doubt I will need a heater much, but when you need it, you need it.
Thanks,
Darryl
Suicide-D is offline   Reply With Quote
Old 12-10-2003, 01:30 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Is it non ac? If so, remove the plastic cover that the "hot - cold" cable runs too and check to make sure the flap to divert the outside air thru the heater core is actually working. This is under the dash on the passenger side. The cable has a clamp that will allow your to adjust it.
I know these things because it was 10 below zero here this morning.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 12-10-2003, 01:34 PM   #3
68 Suburban
68 Suburban's Avatar
Heaters? What are they used for? :p
68 Suburban is offline   Reply With Quote
Old 12-10-2003, 01:36 PM   #4
Suicide-D
it is non-ac... Thanks, I 'll check that
10 below... ouch I couldn't do it.
Old 12-10-2003, 01:53 PM   #5
Suicide-D
Well I think the core must be blocked. I can feel the door move that CPNE said to check. But when it is in the heat position it blows a lot less than when it is in the other position.
I didn’t start the truck so I don’t know if the temperature would change depending on the position.
I guess I know what I get to do after work tonight. Oh Boy!!
I mainly use it for a defroster. I drive less than fifteen miles to work and it rarely gets lower than the low 30’s here
The pisser is I did it last year on my 68… ended up selling that truck in the spring…
Old 12-10-2003, 03:37 PM   #6
mrein3
mrein3's Avatar
Burp your coolant system. The stock configuration of the coolant system has excess coolant vented to the ground. After a hot summer you might have lost a bit of coolant so now you have an air bubble.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 12-10-2003, 04:43 PM   #7
krue
Designated A-hole!
krue's Avatar
I just removed and cleaned out my blower box and vents. Man I got about 10 lbs. of crap out of there! There was so much crap in there! You will be amazed by how much junk accumulates in there.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 12-10-2003, 06:19 PM   #8
pierce
pierce's Avatar
Your thermostat might be stuck in the open position.
69 GMC 1 Ton Longhorn
37 Chevy Coupe
pierce is offline   Reply With Quote
Old 12-10-2003, 10:08 PM   #9
Suicide-D
not as much as i expected...it still doesn't blow as warm as thought but it was a big difference... i'll check the thermostat later...thanks guys
Old 12-10-2003, 10:47 PM   #10
dinnut
dinnut's Avatar
thats quite abit of crap
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-10-2003, 11:00 PM   #11
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
You should also check to see if you are getting coolent flow through the heater core. If not that would be your problem and you would need to replace the heater core. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 12-11-2003, 12:35 AM   #12
cableguy0
back flush the heater core you will probably get a lot of black nasty looking crap out of it. when i replaced mine the old one was 2 or 3 pounds heavier than the new one because of all the crud that was inside of it
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-11-2003, 11:09 AM   #13
Suicide-D
I did back flush the core, several times until the water was clear. I don't think it's getting all that warm. I'll pull the thermostat and put in another one. Which one should I put in 160, 180 or 195?
Old 12-11-2003, 12:41 PM   #14
ckhd
ckhd's Avatar
180.
Make sure that the hose from the water pump goes into the bottom of the heater core.
my 2˘ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
