Old 04-23-2020, 09:22 PM   #1
65chevysub
65chevysub's Avatar
Non tilt column parts question
On my 84 GMC I have a non tilt column that I think is missing an upper bearing spring. My left signal doesn't cancel but the right side does. I replaced the cancel cam, but am wondering it there is supposed to be a spring that goes in the cam? My horn doesn't work either so not sure if non tilt columns are supposed to have the upper bearing spring.
65chevysub is offline   Reply With Quote
Old 04-23-2020, 09:57 PM   #2
Pontiac1976
Pontiac1976's Avatar
Re: Non tilt column parts question
https://bowtieguy.proboards.com/thre...r-repair-renew
Other then the tilt there close should get you started. The horn if you take off the steering wheel off check the horn connection the is a spring there in a sleeve with wire stud horn button pressed makes it beep. There some digrams.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 04-23-2020, 10:10 PM   #3
franken
Just a guess but you might try the help section at the local parts store for the cancel springs in the links.
https://www.google.com/search?client...+cancel+spring
https://www.dormanproducts.com/p-2363-49312.aspx
https://shop.advanceautoparts.com/p/...312/17190371-P
Typically the horn button provides a ground to the horn relay, which might be near the fuse panel. I'd start there. Does the relay click? You might also check for voltage at the horn when pressing the button.
Here's a link for the horn bits. I'd look at the pics and then under the horn button.
https://www.google.com/search?client...sclient=psy-ab
Old 04-24-2020, 08:34 AM   #4
Pontiac1976
www.crankshaftcoalition.com/wiki/images/d/d6/Jazzman_Steering_Rack_Rebuild.pdf
check here for pic's I be level there one here of the none column.
to narrow it down.
