Old 04-26-2020, 10:08 AM   #1
zicc1835
zicc1835's Avatar
WTB ALT Bracket
I need this one its longer than what I have gets the altenator further from the V-cover
zicc1835 is offline   Reply With Quote
Old 04-26-2020, 10:13 AM   #2
NGN
NGN's Avatar
Re: WTB ALT Bracket
I'll check for that in my garage in about ten minutes, might have it not sure, I find things I don't remember having, lol, alright give me fifteen minutes, I'll get back to you.
Nick
NGN is offline   Reply With Quote
Old 04-26-2020, 10:20 AM   #3
zicc1835
zicc1835's Avatar
Re: WTB ALT Bracket
Nick
i do he same thing ...thats funny if you find can you give me a measurement please
Old 04-26-2020, 10:33 AM   #4
zicc1835
zicc1835's Avatar
Re: WTB ALT Bracket
just took a couple pics of what i have this may not be easy to find note the bend in mine put the towel under it so you can see the bend clearly
Old 04-26-2020, 10:39 AM   #5
zicc1835
zicc1835's Avatar
Re: WTB ALT Bracket
I wonder if i attache a longer bracket to the water pump will I get it to line up and not loose the additional reach im looking for
Old 04-26-2020, 10:42 AM   #6
NGN
NGN's Avatar
Re: WTB ALT Bracket
If you don't mind , I sent you a private message with my cell # , give me a call I can send you a pic, also how should I measure this.
Nick
Old 04-26-2020, 10:44 AM   #7
zicc1835
zicc1835's Avatar
Re: WTB ALT Bracket
Nick
from bolt hole to end of adjusting side of bracket .... im going to the PM side now
thank you
Old 04-26-2020, 10:42 AM   #8
1rippen6
Re: WTB ALT Bracket
I believe I have one like that, I will look here shortly.
1rippen6 is offline   Reply With Quote
Old 04-26-2020, 10:55 AM   #9
zicc1835
zicc1835's Avatar
Re: WTB ALT Bracket
TY im going to measure mine
Old 04-26-2020, 11:27 AM   #10
72Cheyenne454
72Cheyenne454's Avatar
Re: WTB ALT Bracket
I believe what you're looking for is the 72 only alt bracket like the top one in the pic.
The shorter version, pictured on the bottom is the earlier style like my 70 had before I replaced it with the 72 style.
72Cheyenne454 is offline   Reply With Quote
Old 04-26-2020, 11:48 AM   #11
1rippen6
Re: WTB ALT Bracket
Here is what I have
Old 04-26-2020, 08:50 PM   #12
zicc1835
zicc1835's Avatar
Re: WTB ALT Bracket
Here is what I have
thanks for looking Im going to see if the one NGN has will fit i can drive to his place
Old 04-26-2020, 08:49 PM   #13
zicc1835
zicc1835's Avatar
Re: WTB ALT Bracket
does the 72 style have a offset away from the block .... I think NGN has one of those i can drive to get it thank you
Old 04-26-2020, 09:11 PM   #14
72Cheyenne454
Re: WTB ALT Bracket
Not sure I understand your question completely, but I think you're asking if the 72 style bracket will have the same offset as the chrome bracket you have pictured above. If that is correct, then yes, the 72 style bracket will have the same offset and will install the same way as your current chrome bracket. The 72 bracket has a longer slot which will allow you to use a longer belt, therefore moving the alternator away from the valve cover for increased clearance for taller/aftermarket valve covers.
Old 04-26-2020, 10:47 AM   #15
NGN
NGN's Avatar
Re: WTB ALT Bracket
I measured it with a flex ruler going around the top, 17 inches . It looks the same,but looks shorter
Old 04-26-2020, 10:50 AM   #16
zicc1835
zicc1835's Avatar
Re: WTB ALT Bracket
your PM box is full i tried to send you a PM
Old 04-26-2020, 10:54 AM   #17
zicc1835
zicc1835's Avatar
Re: WTB ALT Bracket
text sent
Old 04-26-2020, 01:39 PM   #18
Willys_MB
Willys_MB's Avatar
Re: WTB ALT Bracket
I bought that exact alternator bracket from performance online. Not OEM, but it works for me.
https://www.performanceonline.com/Ch...acket-kit-SWP/
1968 GMC C2500 Long Bed Fleetside
Willys_MB is offline   Reply With Quote
Old 04-26-2020, 09:46 PM   #19
firedemon
Re: WTB ALT Bracket
I thought it was just me I only have enough clearance between the valve cover and alternator for a piece of paper . the alternator is at max adjustment took a lot of trips back and forth to the parts store to find a belt to force on
firedemon is offline   Reply With Quote
Old 04-26-2020, 10:21 PM   #20
72Cheyenne454
Re: WTB ALT Bracket
You are not alone. I had to do the same thing prior to installing the 72 style upper bracket. Plenty of adjustment now.
