04-27-2020, 02:57 PM | #1 |
Heater core
How hard is it to replace the heater core on a 72 w/factory air.
I was a professional mechanic for over 50 years & would tie in with anything. I am old now & its hard to get in certain positions. I just hate to have someone else work on my truck. I have studied the manual & it looks dueable. I wonder if a guy left the nut off that goes by the inner fender, it would hold the box up tight. George |
04-27-2020, 04:59 PM | #2 |
Old member
Re: Heater core
Take the passenger inner fender out and it's not bad at all. You are gonna have a bunch of people say you don't have to and they are correct but for the time it will save you it's worth taking it out.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
04-27-2020, 05:18 PM | #3 | |
20' Daredevil (Ret)
Re: Heater core
Andy's right -- trust me, it would have been worth the time to take it out.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
04-27-2020, 07:06 PM | #4 |
Re: Heater core
I dropped the inner fender and took the hood off. I found that plumbers putty works great at making a new seal when putting it back. I tried black silicone but just made a big mess.
Oh, mine doesn't have factory air so I not sure how much more trouble it would be with air. |
04-27-2020, 07:40 PM | #5 |
Re: Heater core
Vey difficult if not impossible to remove the outer air box without moving the hinge/hood out of the way. That being said, heater core is located inside the cab on the a/c trucks. Do your research when getting a replacement heater core. Some replacements are physically smaller and do not fit well.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
04-27-2020, 08:51 PM | #6 |
Re: Heater core
Probably the easiest heater core you will ever do. Replaced mine last fall. I left the hood on, dropped the fender liner. Mine is also factory A.C.
1971 C20 Longhorn 350/350 "Conquistador" |
04-27-2020, 11:32 PM | #7 |
Re: Heater core
I plan to replace mine soon and use the info in this old thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=223703
Jim |
04-28-2020, 03:55 AM | #8 |
Re: Heater core
You can saw a 1” hole or so in the inner fender to get to the hidden nut, i have done it many times. Saves a lot of work on a rusty inner fender.
04-28-2020, 10:11 AM | #9 |
Re: Heater core
70 C20, factory AC. I did mine last Spring. I don't remember doing anything with the fender. I did remove the ducting in the cab. Good opportunity to make sure all the doors are working and the hoses are still intact.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
04-28-2020, 10:26 AM | #10 |
Re: Heater core
I got lucky I gess and the coner was broke off mine so it comes in and out with out to much drama. The only thing about removing the fender well is if it's never been removed you'll be getting the torch out.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
04-28-2020, 10:24 PM | #11 |
Re: Heater core
Thanks for all the help. I am confident I can handle. it now. It shouldn't be a problem to drop the inner fender. I bought this truck last year. It is a low mileage original with absolutely no rust.
George |
