Old 04-28-2020, 06:34 PM   #1
bry593
Question Speedometer Lubrication?
Anyone know how to lubricate the speedometer bushing? Older Chevy's have a cup plug on the side of the cast housing. Under the plug is a felt wick that holds the oil. My 1971 C20 doesn't seem to have this feature. Is it serviceable?
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs
bry593 is offline   Reply With Quote
Old 04-28-2020, 06:48 PM   #2
toolboxchev
Re: Speedometer Lubrication?
Hmmm, have not delved into that one yet. I would bet Lock Doc or the T-Bone will be speaking out to ya soon!
toolboxchev is offline   Reply With Quote
Old 04-28-2020, 10:06 PM   #3
KevinK7
KevinK7's Avatar
This doesn't directly answer your question but I like this stuff for lubing cables...
I 'had' an old bottle of stuff called "Kable Ease". I used it on heater control cables, speedo cables, etc. I really like this stuff. The last time I used it, the plastic container cracked and leaked all out
Anyway, I just googled and apparently it's still available...
https://www.amazon.com/Ags-Kable-Eas.../dp/B000ZO0EA2
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 )
'68 C10 50th
KevinK7 is offline   Reply With Quote
Old 04-29-2020, 01:49 PM   #4
Davidf
Just ordered the linked snake oil. My speedo cable is not bad, but will lube it anyway. But, I want to try it on my HVAC control cables as they are very stiff as they are on my Datsun 240z as well.
Davidf is offline   Reply With Quote
Old 04-28-2020, 10:39 PM   #5
burnin oil
my 4spd ch465 and np205 have splash oiling. Speedo correction box is sealed. For the cable you pull the guts out and shoot some white lithium grease inside it then reinstall the wire.
burnin oil is offline   Reply With Quote
Old 04-29-2020, 07:23 AM   #6
I disconnect at speedo and squirt graphite cable lube in. You can give a shot of air to help it get lower better faster, then add a bit more. That works for me. A more thorough way to go would be remove, clean, lube, install. PITA, yes, but one and done on this, more than likely second lubing in 50 years
Old 04-29-2020, 08:45 AM   #7
mrein3
mrein3's Avatar
Just a quick note for us northern latitude guys. DO NOT use white lithium grease on the cable. You will have troubles when it gets cold out (cold in MN is different than cold in Tennessee).
When I worked in the shop and had a customer complaining about a jittery or noisy speedo cable we would pull it from behind the speedometer, clean it, then lube it with a graphite based lube that won't freeze up in the winter.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 04-29-2020, 01:29 PM   #8
bry593
Correct, use graphite or 10w oil.
Unfortunately, you guys took my thread about the speedometer bushing (at the speedometer head) and turned it into how to grease a drive cable.
So, anyone know how to service the speedo head?
Old 04-29-2020, 08:54 AM   #9
burnin oil
That I a very good point
Old 04-29-2020, 02:34 PM   #10
burnin oil
I didn't realize there is a bushing on the speedo head. I have never done anything to them other than screw the cable in or unclip it. Looking forward to learning something here.
Old 04-29-2020, 07:19 PM   #11
nsb29
nsb29's Avatar
Vaseline Has worked for me for 60 years
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 04-30-2020, 08:46 PM   #12
bry593
Vaseline? I'm asking how to service the speedometer bushing. Wow, just wow....
Old 04-30-2020, 10:12 PM   #13
DeadheadNM
Carpe manana
DeadheadNM's Avatar
This....
Old 04-30-2020, 10:26 PM   #14
Rick Bollinger
I have wondered about this myself. I did use some white lithium sparingly on the gears for the odometer. Vasoline is a petroleum product and it does make sense. The bushing on mine was dry as well and I used sewing machine oil 0 weight but it wont last long. I will add some vasoline I need to pull it apart again to add a trans cooler gauge anyway.
Rick Bollinger is offline   Reply With Quote
Old 05-06-2020, 12:28 PM   #15
bry593
https://imgur.com/UyAeoYs
Here is a link to a pic of a 1967 - 1972, C10 / C20 speedometer head (hope the link works, I'm old and still angry about photobucket). How did anyone manage to apply vaseline to the bushing?
Old 05-07-2020, 10:11 AM   #16
bigmac73
bigmac73's Avatar
Bry593 From one Okie to another where are you from?
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 05-07-2020, 01:39 PM   #17
bry593
Currently in Broken Arrow, just east of Tulsa.
cable, lubrication, oil, speedometer
