Old 05-01-2020, 12:43 PM   #1
msg
Ammeter to Voltmeter Stock look options?
I will be upgrading to the American Auto Wire kit and the ammeter has to go.
Ive snooped in the FAQ and found a few threads on this but they are dated 2013-14 so I wondered if anyone since has other options they have done and made this conversion and had it pretty close to stock looking. Any recent reworks of the ammeter out there?
This was rustbucket66's solution
http://67-72chevytrucks.com/vboard/s...d.php?t=625199
and chevyrestoguy got it looking really close to stock but there was alot of steps that I might screw up.
http://67-72chevytrucks.com/vboard/s...&postcount=318
I also saw Todd White used this shop
https://williamsons.com/
I sent them a message and wanted to know cost to do it.
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 05-01-2020, 01:07 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Ammeter to Voltmeter Stock look options?
Someone on this site changed my ammeter into a voltmeter a couple years ago. I'd have to look at my build thread to find out who, but it is great.
Old 05-01-2020, 01:45 PM   #3
The Rocknrod
Moderator
Just PM'd You.
Old 05-01-2020, 01:55 PM   #4
msg
Thanks man!
Old 05-01-2020, 06:48 PM   #5
Paul Y
I changed mine as per ChevyRestoguys instructions.
Really easy.
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
Old 05-01-2020, 07:24 PM   #6
msg
Really easy.
P.
Did you start with the same Chevy 1979 voltmeter style? I was curious on what years I might have as options as the donor. Glad to know it worked for you.
Old 05-01-2020, 08:08 PM   #7
oldtrux
oldtrux's Avatar
i got a quote a while back from williamsons 175. i'm sure their work is awesome but a little dear for me.i figured just plug one of those little voltage indicators into the cigarette lighter lol.just leave the original gauge in the cluster disconnected.who would know the difference.
oldtrux is offline   Reply With Quote
Old 05-01-2020, 08:44 PM   #8
nsb29
nsb29's Avatar
I bought a small volt meter of eBay and put my 65 face on it popName:  C997EAE5-E2C7-4BA2-8D58-8C1514EB8BF3.jpg
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 05-01-2020, 08:47 PM   #9
oldtrux
oldtrux's Avatar
now thats a cool idea!! bravo
do you remember what gauge it was?
Old 05-02-2020, 10:25 AM   #10
oldtrux
oldtrux's Avatar
Originally Posted by nsb29 View Post
I bought a small volt meter of eBay and put my 65 face on it popAttachment 2010162
Attachment 2010163
could we get a peek of the back of your cluster?thx
Old 09-26-2020, 12:44 PM   #11
roll_the_dice
roll_the_dice's Avatar
Great write up MSG...I did this same swap, but can't get mine to work correctly. How are you going to wire the volt meter with your AAW harness? Are you going to use a unused 12v source for the hot and then ground it on the other post?
roll_the_dice is offline   Reply With Quote
Old 09-26-2020, 12:50 PM   #12
msg
So far the harness is still in the unopened box. I need to crack it open and see what they show. If its not clear in the instructions Id have to give them a call and see. I'll let you know what I find out. Todays mission is clean up a quadrajet thats been sitting up for 5 years or more.
Old 09-26-2020, 05:20 PM   #13
roll_the_dice
Thanks, should be easy...but the easy things aren't.
Old 09-26-2020, 06:13 PM   #14
nsb29
nsb29's Avatar
You did a little neater job on yours than I did LOL you can use any hot lead with ignition On Look at the back of my panel I used AAW all of those pink leads are hot with ignition on and then ground the other one to the case
Old 09-26-2020, 06:34 PM   #15
roll_the_dice
Thanks! I will do it.
He did a neater job than I did as well.
Old 09-26-2020, 03:13 PM   #16
cwcarpenter98
cwcarpenter98's Avatar
That's a good lookin' cluster. Good job!
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
