05-01-2020, 05:37 PM | #1 |
th400 yoke question
Guys i,am switching from a th350 trans up to a th400 trans in my 1972 c10 with a 350 sbc. My question is what size u-joints come fron the factory. 1310-1330 or 1350. I have to buy a new 32 spline yoke.
Thanks again bob
I BELIEVE IN JOHN 3:16 |
05-01-2020, 06:19 PM | #2 |
Re: th400 yoke question
It depends on what driveline combo your truck came with. Most small block TH350 trucks had 1310 joints.
I have a big block TH400 truck that has some 1330 joints and some 1350 in the rear driveline. So bust out your caliper and figure out what you have. As you know, your driveshaft will need to be shortened, so pick whatever size you want and use that if you are replacing one end or having a new shaft built.
05-01-2020, 06:23 PM | #3 |
the last time i did this conversion was around 1993 but I remember having to shorten the drive shaft that was on a 72 LWB C10 and the driveshaft shop put it the yoke and shaft together.
my latest 72 c10 now with a th350 has 1310 is all 3 joints i would take the old joint to the parts store and see if they will match it up maybe that will give you an idea
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
05-01-2020, 06:25 PM | #4 |
also i remember there being a thin walled yoke and a thick walled yoke
05-01-2020, 06:26 PM | #5 |
Bob,
have you done business with Skip White in your town? just looking at some of his engines
05-01-2020, 07:24 PM | #6 |
Ya, i,ve done business with skip whites business. Good prices i must say. I know 1 of there engine builders ,gary mannery and he,s good and been at it for several decades
05-02-2020, 03:14 PM | #7 |
Found out i have 1310 joints so i got a genuine spicer yoke comming off ebay
