Old 05-01-2020, 06:14 PM   #1
C4UC101969
C4UC101969's Avatar
Clutch Pedal Tension Spring
Its been awhile since last time I had an issue that need ya'll input, I was driving earlier today and when I pressed the clutch pedal I heard this snap and ding, after inspecting it I saw the tension spring broke. See pics for details
Few questions I have:
1. Is there like a generic spring I can get at my local hardware store?
2. Where does the broken end go into?
3. Is it safe to drive with it for the time being until i get the spring, as do to all this social distancing and curbside pick ups its kind of hard to browse through a hardware store.
1969 'Matte Blackie' Oshawa Built Chevy C10 Stepside 307 three-on-the-tree
C4UC101969 is offline   Reply With Quote
Old 05-01-2020, 07:41 PM   #2
Jim Boy
Smile Re: Clutch Pedal Tension Spring
Any spring will work as long as it returns the brake arm so as not to have pressure on the release bearing. If you can't get one local try Bills Trucks down in Courtise On. Good luck.
Jim Boy is offline   Reply With Quote
Old 05-01-2020, 07:56 PM   #3
Grumpy old man
Grumpy old man's Avatar
It's the brake pedal return spring . These pics should help .
Old 05-01-2020, 08:08 PM   #4
C4UC101969
C4UC101969's Avatar
Thanks I was going to try Bill's on Monday, now my question can I drive without it for the time being until it gets over here which is god knows when it will be with this virus thing.
Old 05-01-2020, 08:16 PM   #5
Grumpy old man
Classic parts $3.99
https://www.classicparts.com/1967-77...info/71%2D297/
Old 05-01-2020, 08:47 PM   #6
Jim Boy
You should keep the pedal up some how to keep the weighted pressure off the system. Just for the weekend i'd be tying a rope on it and holding it in the cab. That's me though doesn't mean it's right. Have a safe weekend eh.
Old 05-01-2020, 08:51 PM   #7
C4UC101969
C4UC101969's Avatar
The thing is the pedal returns to the rubber stopper no problem, it just now it feels like has less tension but the pedal returns no problem without it.
Old 05-01-2020, 08:57 PM   #8
Jim Boy
Your go to go from what I see if that's the case. I think Bill is open Sat. mornings and he would CanPar it to you. For that little spring it's not worth the drive. Good luck.
Old 05-01-2020, 09:32 PM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
If the brake lights go out when you release the pedal, you're good to go until you get a spring. I'm a bit surprised that the pedal returns to the stop without the spring. How much free pedal do you have on the brakes?
~Steven
Simi Valley, CA
Old 05-02-2020, 01:54 AM   #10
burnin oil
You can definatly get away for a time without it. I have to stick a toe under mine from time to time and pop it off the floor board. I have seen plenty of trucks with bungee cords under the dash from my days working in a junkyard. The classic spring is pretty good. I put one in my truck. Now I just need to repair a zbar to fix my issue. Its been cut and sloppy so the linkage will rub on a header tube and hang up on occasion.
burnin oil is offline   Reply With Quote
