ANybody running WILWOOD #140-10094 complete rear disc kit ?
trying to determine which wilwood braided hoses to use ?
![]() Join Date: Mar 2012
Re: ANybody running WILWOOD #140-10094 complete rear disc kit ?
I am give me a few mins and i will look up the hoses i used, I know i went with a 12 inch line after i ran new brake lines to give me a little extra play when removing the calipers for pad replacements
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
wildwood 220-7686 from summit and actually i forgot they are 16inches
I also had to order some weld on tabs and clips to hold the adapter fittings to the steel lines, I just tached them to the axle tubes. i do not know if you need them or not
do you have the flare adapter for the hard lines?
Hope this helps,. if you can not tach weld the brake line tab on to the axle tube. you might find one that you can clamp on with a big hose clamp.
but the weld on one is the best so everything is stable on the road and will not loosen up or crack a line from stress or movement and just an FYI i have not gotten mine on the road yet as i redoing all lines and my cab is stripped for body work
the rear brake lines I got from Napa and they are the coated ones I just bent them the best i could along the tubes. I ordered whole set from inline tube but they did not really match up ( will use what i can) , so i got the generic ones from Napa in the length i needed
if you are trying to go straight to the rear stock brake lines, They might be too long
mine were rotted so i just replaced , i don't know if you can hook straight to the stock lines depending on the condition and length
Just following up any luck with your swap
