05-07-2020, 12:18 PM | #1 |
17" Steel Wheels 8x6.5
I have been searching for a stock looking 17" steel wheel in a 8x6.5 lug pattern so I can run 1 ton axles on my 69 blazer.
Just looking for stock looking steel wheels but only seem to find them in 16s. And Detroit Steel Wheels makes them in 18s and 20" smoothies. Be nice to run 17s with so many tires choices. 13 |
05-07-2020, 12:45 PM | #2 |
Re: 17" Steel Wheels 8x6.5
Maybe look into later model base trim Chev and Ram wheels. Ram trucks are the same 8x6.5 bolt pattern to this day. Chev changed to a 8x180mm around 2011 I think.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
05-07-2020, 12:55 PM | #3 |
SWB 4x4 Collector
You would have to get those 17"s custom made via Stockton Wheel or another widening shop. 16"s are the only option for a dog dish accepting steel wheel. Only other alternative is using a Dodge Steel Rally looking 8 lug wheel. I believe those are 17"s. You can't go wrong with a set of US INDY MAGS though, I have a set of 17x10"s for my crew cab. I also have a set of the 16x10"s steelies on my crew cab currently.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
05-07-2020, 06:15 PM | #4 |
I hit up Stockton wheels, they can make the Series 22 and Power Wagon wheels in 17x8 and 17x9s.
They can cut the 20 series into 17s but that would require a 5.5" back spacing which would require some spacers on my part. Wasnt sure if there was anyone else that makes that stock looking series 20 wheels in a 17x8 or 17x9 in a 4-4.25" backspacing. 13 |
08-19-2021, 09:30 PM | #5 | |
Hey man, I moved to Austin about 4 years ago...... not sure if you have seen it, but I built a set of 17x9" steelies that came out pretty good. HMU if you want to check them out sometime. -G "I found your thread on CK5 and made the mistake of clicking on it. About dozen and half beers and 4 hours later I found myself repeating, "You have to be f*cking kidding me" and had to close my computer." -13jraven (67-72chevytrucks.com)
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s Find me on INSTAGRAM @MIGHTASWELLK5 '72 K5 - Greg's "Might As Well™" Build |
08-20-2021, 11:58 AM | #6 |
This is the most accurate summation of reading your build thread i've seen
08-25-2021, 03:25 PM | #7 | |
Not to sidetrack the thread, but do you have a pic of your crewcab with the 17x10 US Indy mags on it ? Those are beautiful wheels, wish they came a bit narrower (8", 9" wide) for street tires. |
