Old 05-08-2020, 07:55 AM   #1
fastlane
fastlane's Avatar
I can't be the only one confused about 2nd design bolts!
I'm building an lq4 and replacing the stock TTY bolts with stock bolts. Problem is I can't get the old conrod bolts out. I don't want to smash-whack them out, if I slip I ruin the fractured rod surface. Any Ideas? And no, new forged rods with ARP bolts isn't an option! That'll feed my kids for a month and a half!
1969 Chevy C/10 Stepside, Short Box. LQ4/4L80E swap in progress! (Donations being accepted!)
fastlane is offline   Reply With Quote
Old 05-08-2020, 09:05 AM   #2
CarlsLQ9SS
CarlsLQ9SS's Avatar
Re: I can't be the only one confused about 2nd design bolts!
The connecting rod bolts are not TTY bolts are they? I thought the only TTY bolts on a LS engine was the head bolts. I have never replaced the rod bolts in these engines, but if you want to change them you may be able to clamp them down in a vice to get them out.
CarlsLQ9SS is offline   Reply With Quote
Old 05-08-2020, 12:04 PM   #3
mongocanfly
mongocanfly's Avatar
https://www.onallcylinders.com/2017/...nes-need-know/
Copied this
Which LS Fasteners are TTY?
On a GM LS engine, the cylinder head bolts are TTY and cannot be re-used.
The connecting rod bolts are also TTY, but can be tightened up to three times for bearing checking.
The balancer bolt is also a torque-to-yield fastener.
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-08-2020, 08:15 PM   #4
LS short box
And if I recall correctly if you replace the rod bolts with aftermarket you have to resize the con rods because the new bolts tighten differently. Check over on LS1tech.
Old 05-09-2020, 10:06 AM   #5
AZ 67 C10
AZ 67 C10's Avatar
Pull 1 bolt out, put new bolt in and torque. Do that 16 times. Many people have done it this way with no issues on a stock bottom end. This is assuming you don't have the bottom end torn apart.
Why are you wanting to replace the bolts in the first place? Stock bolts are fine if you don't see >6500rpm consistently. ARP rod bolts are around $100, and I see no need for forged rods unless you're after huge HP.
1967 C10 SWB 6.0 LS swap in progress
2011 CCSB Duramax 4x4
AZ 67 C10 is offline   Reply With Quote
Old 05-11-2020, 07:06 AM   #6
fastlane
fastlane's Avatar
Sorry, I must have been unclear. The engine is completely tore apart. It's awaiting a boring of. 030 to receive +4cc pistons.
The problem is, the bolts don't just come out. There is some sort of sleeve on the shaft of said bolt and pressed into the cap off the conrod.
My question is had anyone else delt with this and what did you do?
Old 05-12-2020, 08:58 AM   #7
mongocanfly
Found this video... https://m.youtube.com/watch?v=F8ISw9Q3CrU
He just basically screws the bolt out..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-18-2020, 01:04 PM   #8
71cadc10
71cadc10's Avatar
tap with a plastic mallet they will knock out.
use soft face something so you don't affect the fractured surface
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
