05-11-2020, 09:39 PM | #1 |
57 gmc hood on a 56 gmc?
The hood that came on my 56 is pretty rough. I have found one off of a 57 that’s in great shape. The guy that’s selling it says it will fit but he could just be trying to sell it. Anyone know if this will fit?
I appreciate your help Thank you |
05-12-2020, 08:27 AM | #2 |
Re: 57 gmc hood on a 56 gmc?
It should fit with no problems.
Only difference is the spears in the 57 hood. Kim |
05-12-2020, 09:51 AM | #3 |
As Kim said it will fit . 57 GMC hood is pretty rare with ribs on top and front emblem opening.
Be sure to check that it is not off a big truck. |
05-19-2020, 08:39 PM | #4 |
05-20-2020, 02:39 PM | #5 |
Just measure your 56 hood that you have . Then measure the GMC hood . Compare
05-20-2020, 08:11 PM | #6 |
Hopefully some one can tell you the easy ways to tell the difference between 55/57 GMC /and Chevy small truck/big truck hoods. I'm thinking that as on the AD trucks the 1-1/2 and 2 ton trucks have a slightly longer hood than the 1/2 to 1 ton trucks. I am not positive on that one as the top of the fender line is the same even though the wheel opening is larger.
55/56 Chevy small truck hood will fit too but you loose that GMC hole in the front that some GMC fanatics view as a sacrilege when you do it.
05-21-2020, 06:22 PM | #7 |
maybe something in here will have dimensions
http://chevy.oldcarmanualproject.com...esto/56071.htm https://www.trifive.com/55-59Assy.pdf |
05-21-2020, 09:09 PM | #8 |
That is just the 3100 section from GM heritage center 56 truck page https://www.gmheritagecenter.com/doc...olet-Truck.pdf
Scrolling down it there is no info as to if there is a difference in length of the hood or front fenders as there is on the AD trucks. Best is to just measure the old hood down the middle and get a couple of measurements to write down and then measure the 57 hood.
05-24-2020, 04:21 PM | #9 | |
Thank you all for your input |
05-27-2020, 07:27 PM | #10 |
Yep, exactly the same.
Thanks ya’ll |
