Old 05-13-2020, 07:23 PM   #1
lynx5653
lynx5653's Avatar
replace top half of cab
need info on replacing upper portion of 55-2 cab due to bent A pillars and sunroof.
thanks in advance for any helpful info
1955 2nd on 86 chassis
Daily driver
lynx5653 is offline   Reply With Quote
Old 05-13-2020, 10:46 PM   #2
mr48chev
mr48chev's Avatar
Re: replace top half of cab
Treat it as if you are chopping it but there is no chop.
At the back I'd cut it where finishing the metal work is the simplest. Probably though the rear window where you can also make yourself a gauge before you cut it to get it set exactly at the same height. The other way and maybe better is to split at the original seam.
Front and I hope Martinsr chimes in on this is to cut layers of the posts off at varying lengths so when you weld it back you weld the inner layer, then weld the outer layers. that way you have each layer welded individually rather than just welding the outside layer and no welds inside.
My ongoing truck projects:
Old 05-14-2020, 12:45 PM   #3
_Ogre
_Ogre's Avatar
bent A pillars can be straightened, we dropped my cab from 3 feet up onto the firewall
sunroof hole can be patched with a section or whole new roof
imo... i'd replace the cab before replacing the top of cab
shop air compressor timer
Old 05-14-2020, 02:15 PM   #4
jwhotrod
big window or small? I have a small back window roof that is cut below back window and about 1/2 way down the A pillars. Im in Illinois 50miles west of Chicago.
jwhotrod is offline   Reply With Quote
Old 05-14-2020, 03:25 PM   #5
mr48chev
mr48chev's Avatar
If you don't already have one a factory assembly manual might be a real prudent investment right now.
This for example although most all of the truck trinket vendors sell them along with others.
https://www.amazon.com/1955-1959-Che.../dp/B006YBPSM4
That would let you figure out where the original welds were and how it was assembled at the factory.
Old 05-16-2020, 03:10 PM   #6
lynx5653
lynx5653's Avatar
thanks for info. guess I will just live with it the way it is
Daily driver
Old 05-16-2020, 11:03 PM   #7
mr48chev
mr48chev's Avatar
How bent up are the A pillers? Tweaked to where the doors or windshield don't fit or just dinged up on the outside? Good photos would help get you some solid advice there.
Old 05-17-2020, 12:10 PM   #8
lynx5653
lynx5653's Avatar
The pillars are tweaked side to side from an apparent hard hit on passenger side It appears previous owner tried to push out passenger side by bracing against drivers side and achieved the opposite result, drivers side pushed out instead of passenger side moving doors and windshield fit and operate just gaps are off . Tried a frame machine but they were not able to tweak them back all the way due to not wanting to damage the new dash that was installed.
My body guy says he can make it work and look presentable so time will tell.
Hard to see in pics so didn't even try
Daily driver
Old 05-17-2020, 02:39 PM   #9
mr48chev
mr48chev's Avatar
Ok. Case of someone who doesn't know what they are doing causing more damage than they fixed.
Old 05-17-2020, 02:57 PM   #10
mr48chev
mr48chev's Avatar
This is an excellent video on welding in a patch panel. A Bit long but well worth spending the time to watch. https://www.youtube.com/watch?v=_u31t13QO6A
