Old 05-17-2020, 09:29 AM   #1
UK62LW
UK62LW's Avatar
Source for 60-63 Heater Knob Metal Clips
Have searched but had no luck - does anyone know if you can buy the metal clips to fit the 60-63 heater knobs to the levers?
I've got a set of new knobs here but no clips - hoping you can get them separately but would buy another set of knobs if that's the only way to go..
Any help appreciated!
Barney, in the UK
1962 Chevy C20
1974 Ford Econoline
1987 Peugeot 205 GTi
1991 Peugeot 205 GTi
UK62LW is offline   Reply With Quote
Old 05-17-2020, 12:18 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Source for 60-63 Heater Knob Metal Clips
I'll have to look more closely at the knobs in my truck, but I thought I didn't notice any clips on it. I thought it was just the plastic that pushed on to the arm. I'll double check though
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 05-17-2020, 03:53 PM   #3
UK62LW
UK62LW's Avatar
That would be much appreciated, thanks!
Barney, in the UK
1962 Chevy C20
1974 Ford Econoline
Old 05-17-2020, 02:41 PM   #4
61K10
61K10's Avatar
I couldn't find any either but that was awhile back a few years. Post up if you find any.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-17-2020, 06:31 PM   #5
cwcarpenter98
I just popped two of the knobs off my truck. The plastic knob just slips over the metal lever. Kinda like a press fit almost
Christian Carpenter
Old 05-17-2020, 10:57 PM   #6
Rolland
The original early type knobs (60-61 and possibly later) did use metal clips inserted into the knobs. They pushed on to the early type levers which were flat on the end. The later type knobs had no clips and were used with the later type
levers which had little tangs on the end to hold the knobs on.
Rolland is offline   Reply With Quote
Old 05-17-2020, 11:00 PM   #7
Rolland
Sorry, to answer UK62LW's question, I don't know of a source for the clips except finding used ones.
Old 05-18-2020, 11:28 AM   #8
jbgroby
jbgroby's Avatar
What I did was use window silicone, this way you can pull them off if needed. After I changed to the new steel levers, I stood the unit up verticle and fixed the knobs. I let dry for a few days and they work well.
jbgroby is offline   Reply With Quote
