Old 05-17-2020, 11:10 AM   #1
old51sedan
old51sedan's Avatar
Transmission Lines
Just installed motor and trans in my truck, 292 w/200-4R, bought a new aluminum radiator. I need to install new fluid lines between Rad and Trans. What is the best way, buy a couple of brake lines and bend my own or try to order some pre-bent?
old51sedan is offline   Reply With Quote
Old 05-17-2020, 12:11 PM   #2
mygmctruck1
Re: Transmission Lines
I went with braided S.S line . Pricy but cuts out lots of problems
mygmctruck1 is offline   Reply With Quote
Old 05-17-2020, 12:24 PM   #3
Sheepdip
Sheepdip's Avatar
If you are not adept at bending tubing this is your answer.
Sheepdip is offline   Reply With Quote
Old 05-17-2020, 01:00 PM   #4
thedudeabides86
Active Member
thedudeabides86's Avatar
Can you use braided stainless for trans cooling lines and also for fuel lines running from the fuel pump up to the carb with an inline fuel filter? I need to rework a few of my lines.
The Dude abides.
thedudeabides86 is offline   Reply With Quote
Old 05-17-2020, 08:38 PM   #5
70STOVEBOLT
70STOVEBOLT's Avatar
I used braided stainless with a Teflon inner tube for my fuel pump to carb. If you use rubber inner make sure it’s ethanol resistant.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 05-17-2020, 10:11 PM   #6
thedudeabides86
Active Member
Where do you usually buy your braided lines?
The Dude abides.
Old 05-17-2020, 09:36 PM   #7
LS short box
I've used -6 SS braided lines a number of times. Trans cooler and fuel lines. Never had a failure. If you go that direction make sure the trans fittings are correct for the trans. I haven't used a 2004R but on 4L60E's they use a specific adapter with straight threads and washer not NPT.
Old 05-18-2020, 09:09 AM   #8
my67c20
I bought prebent lines from In-Line and the fit was 90%. Had to bend a bit more here and there, but much less headache than bending my own. I was doing a trans swap, so did not have old ones for reference.
my67c20 is offline   Reply With Quote
Old 05-18-2020, 10:24 AM   #9
old51sedan
old51sedan's Avatar
Thanks for the replies, while the two transmissions are the same length, I'm thinking the location of the lines are not, regardless the original lines are all buggered up. May be able to save them, but new would be better, especially since both rad and trans are different.
