Old 12-11-2003, 05:38 AM   #1
Piper71c10
Unending Project
Piper71c10's Avatar
Tach Seems high. Or am I?
when Driving down the road with 33" tires and 3.73 gears, I'm reading about 4.5k on the Tach.
:edit: I guess I am high. I meant to say that I'm doing 60mph on the speedo.
If I stab it, it goes over 5k.
anybody care to guess if this is right or wrong?
I've got a sunpro on the shelf I could hook up, but I'm lazy and ya'll know so much.
Piper!
Piper71c10 is offline   Reply With Quote
Old 12-11-2003, 08:13 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Seems a bit high.
Old 12-11-2003, 10:29 AM   #3
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
Yeah, something's wrong. With that setup you should be cruising along at about 2,500 RPM tops. Automatic tranny? Are you sure you're making the 3rd gear shift?
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 12-11-2003, 10:40 AM   #4
Nova_Cobra64
Nova_Cobra64's Avatar
My friends car has that problem......TH350, 24" tires and a 2.70 rear end......turns about 3600 RPM to do 65 and has a top end around 110 MPH. I figure he should be doing about 2200 RPM at 65, and should be capable of doing 150 MPH with the 2.70 gears. He thinks the tach may be out, but it doesn't sound like it. Why else would be be hitting the light side of seven grand in under 3 seconds off the line, yet only running high 14's, low 15's (in a v8 vega).
2004 Silverado - Beater
1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683
2011 Aveo - Work commuter
2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck.
Nova_Cobra64 is offline   Reply With Quote
Old 12-11-2003, 11:58 AM   #5
Paul72
Paul72's Avatar
Sorry, guys, the engineer in me just had to come out. This is like one of those word problems in math class!
From what I figure, you should be turning about 2280 RPM - assuming a 1:1 3rd gear. Sometimes a 33" tire is a little smaller than 33" (My 31's are actually a hair over 30"), but even at 32" it should still be about 2350 RPM.
Sounds like you're off by a factor of 2. Have you got the switch on the tach set to 8 cyl?
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family
Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958
Paul72 is offline   Reply With Quote
Old 12-11-2003, 12:32 PM   #6
BtnkBndt
Pennyless Fool
BtnkBndt's Avatar
Trans slipping??
"Who owns this car with the peace sign, the mag wheels, and four on the floor?"
67 Short Step
283/TH400/4.11
BtnkBndt is offline   Reply With Quote
Old 12-11-2003, 12:38 PM   #7
junkyardjohn
junkyardjohn's Avatar
HI PIPER .... SOUNDS LIKE YOUR TACH IS FUBAR. I RUN ABOUT 2400 RPMs AT 60 MPH IN MY BLAZER WITH 32s. HOWS WASHINGTON?? SETTLED IN OK??? DROP ME A LINE WHEN YOU GET TIME. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 12-11-2003, 01:01 PM   #8
Oborny71
Oborny71's Avatar
like paul72 said, ifs an aftermarket tach, make sure its set to 8cyl. mode, not 6 or 4. this will make it read higher
67 Chevy SWB - goal of a 1,000 hp weekend cruiser
Oborny71 is offline   Reply With Quote
Old 12-11-2003, 01:17 PM   #9
Burnsman
Chevy Freak
Burnsman's Avatar
tach
In regards to the v8 vega, if he is using the stock torque converter (they were dinky), the torque converter doesn't lock up until it reaches a fairly high rpm. The torque converter could be toast too.
69 GMC SWB, 350
70 Chevy LWB, 350
55 chevy gasser, 461
73 Camaro, 496
67 RS Camaro, 406
64 Chevelle, 588
71 Nova, 565
67 Camaro, 461
Burnsman is offline   Reply With Quote
Old 12-11-2003, 03:37 PM   #10
Piper71c10
Unending Project
Piper71c10's Avatar
It's a stock tach, tho I can't tell if it's for the 8cyl or 6cyl. It's not stamped anywhere on it.
The Trans is making the shift. I know that's fine. I guess I'll hook up that other tach today and see what happens. Any reccomendations on fixing my factory tach?
Thanks guys!
Old 12-11-2003, 03:45 PM   #11
Alex Hayley
There should be a hole in the back of the tach with an adjustment screw in it. Using an additional tach, you can set the stock tach by turning the screw until the two tachs match.
Alex Hayley is offline   Reply With Quote
Old 12-11-2003, 05:47 PM   #12
68 Suburban
68 Suburban's Avatar
Piper71c10,
Love the travel trailer!!! What year and model?
Here are pictures of one I had before I sold it to get my Avion Travel Trailer.
http://members.cox.net/topherc/tt/1.htm
68 Suburban is offline   Reply With Quote
Old 12-11-2003, 05:54 PM   #13
Piper71c10
Unending Project
Piper71c10's Avatar
68 burb -- It's a 1950 Sportsman "Aloja" by Modernistic industries. 12' model.
A bigger pic : http://67-72chevytrucks.com/vboard/s...threadid=72079
Caught the edge of one side with the Uhaul on the drive up here and kindof crunched it. Looks like I'm expanding my bodyworking skills this summer.
Piper
Old 12-11-2003, 05:58 PM   #14
68 Suburban
That is a Sweet Trailer! This is what I got rid of my Lakewood for. I still miss that little lakewood
More Pics Here:
http://members.cox.net/topherc/avion/1.htm
Sorry to highjack your thread, but I love these old trailers
Old 12-11-2003, 06:06 PM   #15
Piper71c10
Unending Project
Piper71c10's Avatar
Burb- No worries. I really dig these trailers too. I think they are coming back in a major way as well. It seems like I see them on TV more and more everyday.
Dug that Black and white tile in the lakewood. Did you do that yourself?
Piper
Old 12-11-2003, 06:11 PM   #16
68 Suburban
Piper
Yeah, that lakewood turned out real cool. Nice and homey. I bought it for $500 here in Phx. A friend did the curtains for me. I wanted a nautical theme. The materials cost less than $100 for the curtains. I bought the tile at Lowes and did the checkerboard pattern. I think that was less than $50. I took the range top and had it powder coated black for $15, so it would match the Ice box. Everything else was in decent shape.
You are right about these trailer. I keep getting offered more and more for my Avion. They are only going to go up in value, so if you don't need the money or the space, hold on to it.
Old 12-11-2003, 06:14 PM   #17
68 Suburban
I don't know if you have been to this site, but it is pretty good.
http://www.vintage-vacations.com/trailerlinks.htm
Old 12-12-2003, 03:30 AM   #18
kiley
stock tach
My 72 cst blazer has a factory tach. I always felt like it was running a little high. When I switched to hei i bought a new tach and strapped it to the column. The old tach was running about 500-600 higher than it should at 60 mph.
kiley is offline   Reply With Quote
Old 12-25-2003, 08:06 PM   #19
Piper71c10
Unending Project
Piper71c10's Avatar
So, I pulled the dash to adjust the factory tach, and match it with another I've got laying around.
The factory tach is dead on at idle. Even revving it in park, it's still accurate. Only when I'm doing 60 on the highway is it off. Anyone help on this one?
I S'pose you are going to tell me I need a new factory tach. ...
Piper
Merry Christmas everyone!
Old 12-26-2003, 04:52 PM   #20
Piper71c10
Unending Project
Piper71c10's Avatar
ttt, anyone?
Old 12-26-2003, 05:17 PM   #21
Steven Sellers
Steven Sellers's Avatar
Without having one I cannot take it a part and see if they had an adjustment or what kind of mechanism its running in there. If it is essentially mechanical inside then there may just be a part you can change out, Im sure other year models probally used the same internals.
Does anyone have a junk one they can take apart and take a pic of the innards?
Some tachs are like gauges where they run a sector and gear as their movement and sometimes a tooth goes bad on these.
If I had a factory tach that works like you do I probally wouldnt take it a part and I have worked on thousands of tachs and such, without a lot of replacements I just wouldnt want to take a chance and I would live with it
Steve
2008 Buick Enclave(wifes new non wrecked)
1996 Jeep Cherokee
2002 2500HD 6.0L (traded)
1998 Jeep Grand Cherokee(wifes/wrecked)
1977 DJ5 postal jeep(mmm lots of fun)
1988 Toyota 2wd p/u(DD, blewup 199,000)
1991 Toyota 2ed p/u (sry just cant break these things)
1997 XR70 Honda
1991 Z50(FOR SALE)
1972 Z50 Honda
1970 SWB 350/knucklebuster "The adventure begins and I am confident that there will be no end".
Steven Sellers is offline   Reply With Quote
Old 12-28-2003, 03:40 AM   #22
Longhorn Man
The way I look at this, is the stock tachs were never too acurate when they were new...let alone 30+ years later.
If you want a tach to look neat and to have another option...get a stock one.
If you rip the truck through the gears, get a good aftermarket one.
Even an Auto Zone one would be more acurate.
Old 12-28-2003, 03:49 AM   #23
magoo72
magoo72's Avatar
thats why i went to a 3.08 gear,on the interstate i be turning bout 4 grand!with my 3.73's
but.........i may be high too,yanno to many ''burn outs"
magoo72 is offline   Reply With Quote
Old 12-28-2003, 06:44 PM   #24
Piper71c10
Unending Project
Piper71c10's Avatar
Ya know, It's a little circuit board on the back of the Tach. I guess i'll dump the whole cluster on ebay.
Who knows. I don't really need the tach, but it's nice to have.
Thanks for the replies.
Piper!
