Oil cooler lines/hoses 1983 454
Looking to replace my seeping oil cooler lines...here is what my online research came up with...but I am looking for actual experience before I order.
Lower inlet: 34 inch. GM ac delco 12472195 or Dorman 625–131 Upper outlet: 28 inch. Gm ACDelco 12472194 or Dorman 625-617 OR Other upper hose: 47 inch. GM ACDELCO 12472196 or Dorman 625-132 By looking under the 1983 C20 Suburban 454 in question...the hoses basically look the exact same...so I am tempted to order 625-131 and see if it will fit both positions...because it is cheaper than the others. I can not find thread sizes on any of these hoses, but they all “look” about right in their pictures, and the shapes look right. Any experiences from the greater good? Thanks in advance. |
Moderator
![]() Join Date: Oct 2008
Re: Oil cooler lines/hoses 1983 454
If the steel portion of the lines is in good shape you can cut the crimped clamping ring and peel it off.
Then replace the rubber hose with SAE J1019 oil cooler hose. Use Oetiker ear clamps or German Fuel Injection clamps.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 05-22-2020 at 11:43 PM. Reason: Edit the typo in SAE number |
Yes...the metal portion looks good still.
I can see where to get 1/2 inch oil hose online. Do you have a favorite online source for those German clamps? Hard to find them and their various sizes. |
Moderator
My dyslexia is showing.
Oil cooler hose is SAE J1019 hose. I get assortment sets. FI clamps... https://www.amazon.com/Sutemribor-Si...07D13PGK6?th=1 Oetiker clamps... https://www.amazon.com/DYWISHKEY-Sta..._t4_B07D13PGK6
And please let us know if and how your repairs were successful. |
New info parts numbers to add:
If you buy Hayden 112 it is Gates brand hose. It is best to use a 18-20 mm sized fuel injection clamp...my 16-18 mm just barely fit. The two hoses on my 83 are almost completely identical except for a tiny bend in the long metal tube near the oil filter adaptor. The oil filter adaptor housing uses a gasket and an o-ring between it and the engine block. Some auto parts list a Dorman kit for this but it’s wrong. The proper gm part for the gasket and o ring is 88893990. |
