Old 06-03-2020, 09:46 AM   #1
phlegm
Still Green but learning
phlegm's Avatar
Slip over cab support cover
Hi guys, I have done some research on here and fully understand that in most cases when u have a cab support rusted out there are larger issues. In my case however I believe I can cut out the cancer, hose it down with inhibitor and then put in the slip over.
Couple of questions, has anyone put one of these on? Do they just bolt over or are you suppose to tac them in with a welder (I dont have one or the skill set).
Looking for some experience before I order the part.a
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 06-05-2020, 09:01 PM   #2
phlegm
phlegm's Avatar
Re: Slip over cab support cover
Anyone??
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 06-06-2020, 02:52 AM   #3
GMCPaul
They needed to be welded and the slip over version holds moisture between old existing metal and new and generally rust back out within a short time span. Generally used by people looking to flip something as cheaply as possible with no thought towards a long term lasting repair. We won't even sell them.
Paul Jr @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 06-06-2020, 11:12 AM   #4
57taskforce
All about them K’s
57taskforce's Avatar
I only cut the flower halves of my supports off as the uppers at all four corners were solid. I then grafted in the lower halves from the replacement floor support panels. The supports are a pretty important part of the structure of the floor, as Gmcpaul said they need to be welded in for sure.
Tyler
Old 06-08-2020, 03:22 PM   #5
phlegm
phlegm's Avatar
Paul Jr @ GMCPauls
Thanks Guys, this is what I needed. This is a more complete answer than what I had seen previously. I am going to need to go ahead and replace the whole thing.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
