Active Member
![]() Join Date: Jul 2014
Fuel tank relocation
I'm going to replace my in cab tank, was considering the LMC relocation kit with the 21 gallon tank. Fairly certain I'll never replace motor to an LS series motor, anyone and feedback/thoughts on the LMC kit? Thanks in advance, B.
Re: Fuel tank relocation
I had and fit one in my truck, I did not like how visible it was from behind the truck. I went with a Boyd tank and painted the back black, if I had painted the LMC tank I may have not noticed it as much.
Active Member
Do yourself a favor and delete LMC from your bookmarks and throw the catalog out.
Performanceonline.com sells a real nice 19 gallon aluminum baffled tank for a reasonable price. I installed one 3 years ago. Nice tank and angles toward back so it doesn’t look like a bubble hanging below the truck. Posted via Mobile Device |
#5 | |
Active Member
a 1969 Camaro gas tank works well in the rear
Active Member
Thank you
yes, there are some threads about it, good luck
Trouble with that is Lmc does have odd bits other shops dont carry
Front parking brake cable for example i have only seen it offered elsewhere if you buy a new parkbrake peddle |
I ran 3/8 steel fuel line with a 40 gallon suburbon gas tank
![]() Join Date: Feb 2019
What year Suburban Tank did you use?
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
1st one was out of a late 70s burb
I used to have this in my 68 until it leaked New one 90s burb tank i ordered it from napa i have a set of suburbon tank cross members i scrounged years past probably from the same truck i got the first tank from I am going to say 96 i ordered it to be able to fit a standard fuel sender or fit a 96 97 burb vortec fuel pump sender setup as i was going to put a vortec injection setup on my 72 before i changed my mind to go carb instead I will probably order a second one this winter as i have a low rider i am going to build with a 99 vortec 350 I would like to go ls but i have a low milage vortec 350 You can look at smaller tanks as well I believe 25 30 40 gallon are some of the range in these trucks https://www.rockauto.com/en/catalog/...fuel+tank,6268 |
