Bed removal
This is a strange question but it's the only way I can do the project. Can I remove the bed on my 84 Sierra one piece at a time, and which piece do I remove first? I need to replace the front bed panel, but also want to clean the chassis, and replace the original rubber fuel lines and sending unit. I dont have any help to get the bed off in one piece.
Thanks |
Re: Bed removal
I know for sure that 75 is full bolt un-bolt bed if needed. I not sure how far up they went pretty sure 84 has some panels that have some spot welds but are for the most part bolt new ones in. I think if you look around the tale gate area's you see for sure.
You can try the area's see if come out then look for spot weld if it not to badly rusted you or to much paint on them they show easy. Maybe some other know how far passed 75 they went.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
Re: Bed removal
You can do it but it would be exceedingly frustrating. As a few of the bolts will be blocked by the cab or frame, and the bed will have to be pulled back a foot for room.
A cherry picker with truckers rope can easily lift a bed so you can drive out from underneath it. Then 6 buckets make a decent holder for it while you pull it apart. Liberly soak the bolts in PB blaster for a day or two to help. Also a impact gun, amd a mapp gas torch will come in handy. |
![]() Join Date: Dec 2009
Re: Bed removal
Remove tailgate.
Remove rear bumper. Disconnect taillight harness. Check if rear axle vent tube is clamped to the bed(still). Use a wrench (Ratcheting wrench would be nice) and remove bolts that hold front bed panel to fenders. Grind welds on rear bed post (check out link in video below) Disconnect the fuel filler neck. Then take all the bolts out of the side fenders. Take side fenders off. Then remove the bed floor bolts. Then remove floor. Link: https://www.youtube.com/watch?v=ywSQ9lUSeWs .
![]() ![]() Join Date: May 2015
Re: Bed removal
I've removed beds by myself before...remove all bed2frame bolts, set some sawhorses behind the truck, and you can "walk" the bed off the frame onto the sawhorses...I've also seen people use engine hoists and ratchet straps to remove a bed...if you dont have a engine hoist ,you can rent one
I know you said you dont have help, but 4 people can lift one off in a matter of minutes...
Re: Bed removal
IIRC - there are a couple of spot welds back by the tailgate. Most everything else are bolts. The problem is a lot of the bolts are going to be nearly impossible to get to without pulling the bed or at least sliding it several inches to the rear. And a lot of those bolts/nuts are probably rusted to the point of having to twist shear the bolt to get it off.
I was able to replace the tank hoses on my 75 by sliding the bed to the rear. A hungry mouse had sampled both suction hoses on a dual tank setup. Not sure the senders will clear the cab as I didn't replace those. Sliding the bed is doable by yourself. Can you somehow obtain an engine cherry picker? Those are supposed to be able to pick the bed off the frame. |
Re: Bed removal
Thanks everyone. The one thing I forgot to mention is my apartment has a dirt/rock driveway. I'll try the sawhorse trick and slide it back on to them. My topper is sitting on them right now but it will be moved in a couple weeks. Pic is of my truck with topper on.
Re: Bed removal
Add to the list above:
Start spraying any bolts/nuts with penetrating oil several days before the planed removal. Have a large rock, heavy tool box, etc to set on the heads of the bed bolts to keep them from raising out of the holes and spinning as you loosen the nuts. The bed bolts are carriage bolts and if you strip out the square hole in the bed or the square on the bolt, the removal job gets a lot harder. |
#9 | |
Re: Bed removal
![]() ![]() Spray only the nut on the carriage bed bolts. That way is the bolts are stuck in the bed they will stay there.(Maybe) .
Re: Bed removal
When I pulled the bed off my 73 many years ago, I cut a couple pieces of 4x4 (?) just long enough to fit cross-ways under the bed rails. Then I lifted it with chains from a forklift. I know you don't have a forklift, but you could use an engine hoist, a stout tree limb, or rig up some sort of gallows out of scrap wood.
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
#11 | |
Re: Bed removal
I have done cinder blocks and 4x4 also, by myself (really helps to have someone add blocks while you hold up one side) and driven/rolled the truck out from under the bed. |
Re: Bed removal
This is how I did mine.
Remove tailgate. The wheel wells, wheel house have a ton of bolts and can be removed first thing. Like 2 on each end, 8 connecting to the floor and a bunch connecting to the bed side. Then push down and out after removing tires. Then you can do the bed sides. 3 or 4 bolts connect to front bed panel. spot welds by tailgate. My swb has 3 bolts in front and behind wheel house connecting side to floor. Then you have some brackets and braces that all bolt on. Once you get the sides off is easy to handle the floor with front panel attached by yourself Good luck
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Bed removal
easiest way to remove the bed is four eye bolts through the stake pockets with straps and a motor hoist.. for good measure i stick a rolled up moving blanket bu the lower rear panel so it doesnt smash into the hoist's hydraulic boom
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Re: Bed removal
Lots of good info here already, so I won't add to it. But I will say, you got a clean truck, and about to get cleaner! Good luck!
