Old 06-14-2020, 03:01 PM   #1
apacheandy
Fitting a frame mounted brake booster/master with a 4L80
I’m installing a 6.0 LQ4 with a 4L80 into my ‘59 Apache and I’ve also got a frame mounted brake booster. I’d love some pics if someone has done this before. I know I’m gonna have to move some mounts but just not sure how to fit it all in. Thanks!
apacheandy is offline   Reply With Quote
Old 06-15-2020, 08:33 PM   #2
Johns327
Johns327's Avatar
Re: Fitting a frame mounted brake booster/master with a 4L80
The trans is a big beast, I used to have a turbo 400, no issue but that 4l80 is bigger. I don’t have the engine you have, and engine setback is going to matter. The main connector on the back of the trans hit my master cylinder and power assist canister. I ended up slicing the brake mount and adding a spacer to push it back. That also meant the brake push rod needed to have some added to it. You can see the spacer icon the brake mount.
1955 second series, 3200 standard bed, big window. Owned since 1975, decided it was time to do a frame off. 327, 4L80e, Ford 9 inch.
Johns327 is offline   Reply With Quote
