06-26-2020, 03:04 PM | #1 |
Venting gas cap
Went to change my in line fuel filter and fuel was pouring out. Not good. that fuel could get past my carb float valve and into the oil. Have a Strat locking cap. Decided to drill a small hole somewhere in the cap. But wait!!! There is a gasket on that cap,I removed the gasket,problem solved. There is a flap in my tank neck to keep the fuel in and a somewhat seal w/the cap. The idle seems to be more regular and I think I may have improved my mileage.1984 K20
06-27-2020, 09:41 AM | #2 |
Re: Venting gas cap
Thanks for sharing that info I think I will try this as well. I have my vent tube blocked off because when I used a 3 line fuel pump it kept flooding so I went back to a 2 line pump. I felt like the tank needs to be vented
79 Chevy 2wd BIG10 350 TH400 |
06-27-2020, 09:47 AM | #3 |
Re: Venting gas cap
The tanks DO need venting. On early pre-emission tanks, the vent was a short piece of hose ending in a plastic vent of the type used to vent rear end differentials. The hose hung off the end of the 2nd pipe out of the sender unit.
A non-sealed gas cap may lead to gas leaking out on acceleration. These long tanks have a large 'slosh' factor. |
06-27-2020, 10:12 AM | #4 |
Re: Venting gas cap
Alot of folks eliminate the charcoal canister under the hood thinking it is robbing HP. I think the entire purpose of the canister is to vent the gas tank and capture the fumes. Then, when the engine is started, it sucks the fumes into the engine air intake.
Maybe look to see if the canister is hooked up or clogged?
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
06-27-2020, 05:56 PM | #5 |
Re: Venting gas cap
To add to what Jay said, around 70 the canister was added and vented caps went away.
06-28-2020, 09:50 PM | #6 |
Re: Venting gas cap
First off you have to buy or get the right gas cap for your set up be it vent gas cap or none vent gas cap
Tip: To those that have triple lines on the fuel pump have a none vent cap. and the other is has vented gas cap.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
