![]() Join Date: Jun 2016
WTHeck - klunk!
Has anyone ever found the problem of the mysterious KLUNK to be in any one of the input / output / adapter with the arrows in this picture - or a combination?
Tap the gas peddle on and off and the KLUNK from hell is still happening. All U joints are new, Transmission has fluid, tie rods/ends are tight, motor mounts are a year old... BTW - not my picture - I pulled it from another thread. Thanks in advance! |
![]() Join Date: Mar 2003
Re: WTHeck - klunk!
Pretty common, the splines get worn out and have quite a bit of slop in them. Take a close look and you will see it along with the coupler inside the adapter. The 4 speeds are the worse for it.
Re: WTHeck - klunk!
Okay thanks...
I should have mentioned it's a stock th350 4x4 auto trans/adapter/np205 Thanks again! |
![]() Join Date: Dec 1999
Re: WTHeck - klunk!
As kwmech stated there could be slop the coupler sleeve. I damaged a few in my k20 when I had the manual (10 spline) and after I swapped to a th350. Though take note that the 205 is an old gear driven box. While it is strong it is not built with tight tolerances or for quiet operation.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#5 | |
All about them K’s
![]() Join Date: Jun 2014
Re: WTHeck - klunk!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() Last edited by 57taskforce; 07-01-2020 at 01:47 PM. |
Re: WTHeck - klunk!
Thanks...I'll have that looked at!
Re: WTHeck - klunk!
the idler gear bearings are set with shims . if they get sloppy they can BANG back and forth in the case under power and off power like you have said .
you might be able to pull a fill plug or drain plug and see if you can push the idler gear in the case . if you can it needs to be checked out for bad bearings or re shimmed .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
![]() Join Date: May 2012
Re: WTHeck - klunk!
"KLUNK from hell" do you have a Detroit Locker"
j
White K20 |
Re: WTHeck - klunk!
#10 | |
Re: WTHeck - klunk!
This is an original No Spin(Detroit locker) in an Eaton. Just saying, you might want to be sure where slop is originating. So you may have one as original.
j
White K20 |
Re: WTHeck - klunk!
I don't remember my 73 or 80 or 71 being noisy in the T/C. Of course they were all new or relatively new back then. I think the 71 got up to 90K-something when we sold it to buy our first Suburban (2wd). The 73 was in the 70-80K range when I traded it for the 80, but I sold the 80 at about 22K.
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
![]() Join Date: Feb 2000
Re: WTHeck - klunk!
Some trucks came with the No-Spin from the factory - it is the same as a Detroit Locker. Check you SPID just to be sure. They can be very klunky.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#13 | |
Re: WTHeck - klunk!
![]() j
White K20 |
Re: WTHeck - klunk!
Before tearing into the t-case maybe drop the driveshaft and check the yokes on both the t-case and rear end.
#15 |
Re: WTHeck - klunk!
Ha...okay - thanks fellas'.
I had the rear axle rebuilt not too long ago...new bearings, one shaft and new gearing put in. But thinking about it, I honestly can't say whether or not the yoke was replaced! So I'll drop the driveshaft and have a look. If nothing appears wrong back there then it's on to the Adapter coupler... Thanks again! |
#16 |
Re: WTHeck - klunk!
Did not mean the actual yokes. Rotate the yokes back and forth to check slop in the t-case/adapter and diff.
#17 |
Re: WTHeck - klunk!
I ordered a '92 K3500 6.5TD/NV4500 pickup. When I went to pick it up I drove it around the lot with the salesman riding along. It clunked (more like clank) when on and off the throttle and I mentioned that. He said "That's normal". I accepted that as typical for what a salesman will say, and I'll watch it under warranty and see how it goes. I drove that truck for 22 years, of work, and 335k miles and never changed a u-joint.
Take any truck, jack rear wheels up, grab a tire, and move forward and back. What happens? There is slop and you hear it
#18 | |
Re: WTHeck - klunk!
#19 |
Re: WTHeck - klunk!
Notes taken, Fellas' - appreciate it!
I'll have some time this weekend to have a look... |
