Old 07-05-2020, 02:50 PM   #1
sick472
sick472's Avatar
400TH Kickdown Wiring - Fused/Relayed or not?
I have a Turbo 400 in my 72 now and will be adding the kick down switch at the gas pedal. I can't find any Chevy diagrams (if it's in my assembly manual...It's hiding real good).
I think I know that it needs IGN switched power, but does it get fused (if so, what size fuse?)?
Should it utilize a relay? I'm sure I have seen the kickdown relays NOS for sale. Not that I have to be 100% concourse correct, but I do want to do it right.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 07-05-2020, 03:04 PM   #2
72LB
72LB's Avatar
Re: 400TH Kickdown Wiring - Fused/Relayed or not?
Depends on if you have an older 400 or newer. When the 400 in my 69 went south I had a newer one here in the shop I had rebuilt. It required a kickdown as the older one didn't. I went with the Lokar kickdown kit, All you had to do is run a wire to a switched connection at the fuse block and the other went to the sender on the trans.
https://www.speedwaymotors.com/Lokar...20(Feb28_2020)
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
Old 07-05-2020, 03:43 PM   #3
BigBird05
Fig.36 & fig. 37 of the 72 service manual. 18 ga pink to the pedal switch, 18 ga org. from the pedal out to the trans conn.
BigBird05 is offline   Reply With Quote
Old 07-05-2020, 04:40 PM   #4
sick472
sick472's Avatar
Thanks folks... Does the pink wire have a fuse inline? I assume 18 ga wire does not need to be relayed.
1972 C10
1985 K20
Old 07-05-2020, 06:09 PM   #5
HO455
HO455's Avatar
My 67 doesn't have a fuse or a relay. Neither does my GTO. The coil in the transmission draws very little current.
RIP Bob Parks.
Old 07-05-2020, 08:25 PM   #6
BigBird05
The pink wire plugs into the fuse box. No inline fuse, no relay.
