07-12-2020, 01:35 PM | #1 |
SB StepSide angle strip removal
Has anyone ever removed the angle strip from a bedside of a stepside? The truck I bought a bit ago (which is eating my lunch) has rust bubbling up behind the strips. I picked up new strips but it appears the original ones are spot welded on - many times......
I would rather not destroy the bedsides trying to grind them off :/ Any guidance would be FANTASTIC! |
07-12-2020, 05:44 PM | #2 |
Re: SB StepSide angle strip removal
spot weld cutter on drill . drill each one and pop off and clean / dress / weld in new .
unless there reg welds and not just pinch / spot welds .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
07-12-2020, 06:09 PM | #3 |
Bad thing about a spot weld bit is that itll drill thru your bedside to cut the spot weld out....
Actually grinding the welds off will do the least amount of damage...but if your gonna weld the new strips back on the paint damage or holes wont be a issue...
07-12-2020, 06:19 PM | #4 |
only if you go to far with he spot weld cutter bit .
been using them for years no problems . slow and steady wins the race with them .
07-12-2020, 06:38 PM | #5 |
laying low
Good how to info here.
https://www.stovebolt.com/ubbthreads...&Number=325959 Somewhere there is info in our 67-72 forum too.
