Old 07-14-2020, 04:35 PM   #1
Toro
Toro's Avatar
Spot weld removal, best method/tool?
I wanted to see if any method or tool/bit was preferred over another for removing spot welds. In this case, particularly with rocker panel replacement. Thanks!
Toro is offline   Reply With Quote
Old 07-14-2020, 05:38 PM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: Spot weld removal, best method/tool?
I always stock up on spot weld cutters at harbor freight for the job.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 07-14-2020, 05:50 PM   #3
twoskies
twoskies's Avatar
harbor freight spot weld cutter, keep a cup of oil handy, dip cutter couple times during cut, makes them last longer, worked for me, Good Luck with your build
A Little Better Every Day
Cancer Survivor, most dont know what they have until its gone, appreciate everything
twoskies is offline   Reply With Quote
Old 07-14-2020, 06:05 PM   #4
Old_Truck_Fan
I've had good luck with the Blair spot weld cutter, model 11094.
https://www.blairequipment.com/spotweld-cutters
1968 SWB C10 http://67-72chevytrucks.com/vboard/s...d.php?t=508675
2011 Dodge Ram 1500
2012 Camaro ZL1
Old_Truck_Fan is offline   Reply With Quote
Old 07-14-2020, 07:25 PM   #5
chevmn
like others, I used the Harbor Freight cutters. Agree with using oil, do not use excessive force, and buy a few, as they will snag and break, but often you can keep using. The cutter is reversible, so once it is too bad to cut, just unscrew, flip over and go again. I just did a few dozen earlier in the year, between both rockers, inner roof panel, and a cab corner.
chevmn is offline   Reply With Quote
Old 07-15-2020, 09:00 AM   #6
Andy4639
Old member
Andy4639's Avatar
Torch and heat. Then chisel them a part.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 07-15-2020, 11:16 AM   #7
Willie Makeit
Willie Makeit's Avatar
another vote for the Blair cutter.
Willie Makeit is offline   Reply With Quote
Old 07-15-2020, 12:28 PM   #8
SkidmoreGarage
Just to pile it on, the Blair tool is great even on modern cars which use more exotic steels (harder), thinner metals, and engineered spot welds. It is a much better tool than the HF version. Mine hasn't broken any teeth and it's still very sharp.
Just center-punch and let the tool do the work. It isn't the fastest, but once you get the technique, it is pretty efficient and both panels are usable.
SkidmoreGarage is offline   Reply With Quote
Old 07-15-2020, 09:03 AM   #9
my67c20
It all depends if the panel in front is the one you want to save or not. If you want to save the panel in front, then I usually just use a 1/4" drill bit and drill until the point is exposed on thru the back panel, then I use a panel splitter from Eastwood, or a putty knife and hammer it thru to break the spot weld. Hammer and dolly any distortion. If the panel in the panel in the back is the one I want to save, then I use my cutoff tool and grind away the weld area from the front.
my67c20 is offline   Reply With Quote
Old 07-15-2020, 09:35 AM   #10
Davidf
For rusty pieces, I usually just use my air chisel. When I want to be careful, I use a spot weld drill bit similar to this: https://www.northerntool.com/shop/to...gaArJnEALw_wcB
Davidf is offline   Reply With Quote
Old 07-15-2020, 02:55 PM   #11
DPowers
One foot in front of the other
DPowers's Avatar
SpotClaw
https://www.ebay.com/itm/SPOT-CLAW-5...-/130543543466
DPowers is offline   Reply With Quote
Old 07-15-2020, 09:15 PM   #12
hugger6933
I like the H/F 1/8 double ended drill bit. I'll drill out the center then use a step bit to drill out the weld. I also bought a pair of STECK brand spot weld breakers on is flat the other has a 90 degree elbow.I also have a Snap-On brand spot weld cutter it is quite pricey I think I gave like $450 ten or so years ago. But I have done ten spots in less than a minute with it. Of course a die grinder with a cutoff blade if your not trying to save both panels, grind on the waste side till it pops loose. Any tool you use try those steck or similar type spot weld breakers. Look into them I use them a TON. JIM
hugger6933 is offline   Reply With Quote
Old 07-15-2020, 09:22 PM   #13
Bigdav160
Bigdav160's Avatar
I think I've purchased every spot cutter there is. My favorite is Spot Eze
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-16-2020, 06:39 AM   #14
Getter-Done
Getter-Done's Avatar
Here is the best one I have used.
Link:https://autobodymetalcuttingsupplies.com/
84 Chevy K-20
Old 07-16-2020, 03:02 PM   #15
72c20customcamper
72c20customcamper's Avatar
I've always used a 3/8 or 1/2 drill bit. Drill into the spot weld but try not to do all the way threw the weld and just a few taps with a chisel. Been doing it this way since the 70s at my uncle's shop. Rockers on my 68
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is online now   Reply With Quote
