AC control lights?
My air conditioning control panel lights haven't worked since I don't know when. I just got them working. I put on new sockets and bulbs and now they work. There are two lights on the air conditioning control panel. One comes off the main under dash harness and the other from the air conditioning harness. The light from the main harness works in conjunction with the cluster lights, but the one from the air conditioning harness comes on with the ignition. Is that normal or do I have a problem. Seems strange to me. Thanks for any advice.
Old member
Both lights should work off the head light switch. Grey wire coming off the switch. Disconnect the one that comes on with key and tap into the one that works with the head lights.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#3 | |
Re: AC control lights?
The power for both bulbs ultimately goes through the light switch so that they both dim accordingly.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
The power for both bulbs ultimately goes through the light switch so that they both dim accordingly.[/QUOTE]
I expected it to work like you describe, but mine is not controlled by the headlight switch. It comes on when the key is on and stays on. Any Ideas why? Could my air conditioning harness be plugged into the wrong spot on the fuse box? |
If memory serves me correctly, there will be a grey wire with a single female plug that is part of the AC harness that should plug into the fuse box near the top right that is labeled "cluster feed".
Yours is probably plugged in the "Ign Unfused" spot.
That was it. It was plugged into ignition unfused instead of cluster feed. Thanks.
