Old 07-23-2020, 06:05 PM   #1
cj847
cj847's Avatar
Need panel fit expert
How would you remedy this?
My door to fender gap is exactly a paint stick wide and the alignment is a straight line. Should I widen the gap or shim the fender out a 1/16- 1/8"
or so?
I know that the 60-66 models the fender actually sat outside of the door but I thought the 71 had more refined lines.
I want it set before I replace the trim the previous owner ruined.
Thanks in advance.
Name:  door align.jpg
cj847 is offline   Reply With Quote
Old 07-23-2020, 06:34 PM   #2
72c20customcamper
72c20customcamper's Avatar
Re: Need panel fit expert
Fender has a nice straight gap to the cowl. I would look into moving the door back if possible . How's the gap to the door to the rear piller
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 07-23-2020, 07:00 PM   #3
Boog
laying low
Boog's Avatar
67-72 trucks were not built to 1/8" tolerances. They routinely left the plant with more than that. I would adjust the fender forward just enough to clear that trim.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 07-23-2020, 09:07 PM   #4
HO455
HO455's Avatar
Before adjusting check the gaps around the window. Some times the window frames are not installed correctly from the factory. Just my past experience that sometimes you can't get even gaps because your door was made on a Monday.
RIP Bob Parks.
Old 07-23-2020, 10:07 PM   #5
cj847
cj847's Avatar
All valid comments.
The back of the door frame is actually just about to rub the cab (the lower part of the door has just under a paint stick gap). The window frame needs to be bent toward the cab as it is not touching the rubber seal. #madeonmonday or dropped several times...lol
Interesting that on the passenger side the gap is even smaller and the trim clears.
I think I am going to move the fender forward. It looks like that will help the gap at the grill (tighter on one side than the other).
Question> to adjust the door does the fender have to be removed?
Old 07-23-2020, 11:13 PM   #6
DD1
Originally Posted by cj847 View Post
All valid comments.
If you want to adjust the door forward / backwards, you would need to remove the fender. If you can manage to move the fender forward that might be the best thing to try first.
I suggested on my thread that you can try shimming the radiator support. But never mind as that would increase the gap on the lower part of the door and I just realized your molding is on the top. If the fender can go forward, that would be best, even if it means the top on bottom of the fender is not a perfectly even gap. Keep in mind that when you move the fender forward, you should check the gap on the other side to see if anything changed.
___________________________________________
Darien
1971 C10 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=502964
DD1 is offline   Reply With Quote
Old 07-24-2020, 08:44 AM   #7
72c20customcamper
All valid comments.
Doesn't have to be removed. These were in every bodymans tool box in the 70s. I've made my own with cheap wrenches.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-23-2020, 11:25 PM   #8
DD1
Another thought.. Is it possible to move the trim back a bit? The trim looks closer to the edge of the door than it does the fender, but it could be the picture messing with my eyes. Is the trim in the exact same spot on the other side where you don't have the problem?
Darien
1971 C10 LWB
Old 07-24-2020, 08:45 AM   #9
Davidf
If the window frame is not touching the rubber seal then the you need to adjust the top of the door inward. The distance from the door the door seal lip should be consistent all the way around the door. If you move the top of the door inward, then I bet the trim will clear the fender.
Davidf is offline   Reply With Quote
Old 07-24-2020, 09:02 AM   #10
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Put an 1/8" shim at the top of the fender moving the cowl and fender out from the cab. You maintain your fender to cowl line and give the door edge clearance. The factory usually installs a shim or two there. Sometimes the bottom of the fender is shimmed out with those key shaped shims...Just a thought.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
