07-26-2020, 02:13 PM | #1 |
Axel won’t go in
I replaced the axel seals on my 72 k20 (1978 14 bolt rear) and I can’t get the passenger side axel in the last 4 & 1/2 “, any ideas why?
We where winning when I left |
07-26-2020, 02:34 PM | #2 |
Re: Axel won’t go in
Do you have the rear cover off? Spider gears may have moved on the other axle installation.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
07-26-2020, 02:35 PM | #3 |
Definitely check the spiders. Also, when you're trying to insert it, the shaft is balancing on the outer bearing. Try moving the flange up and down while rotating it.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
07-26-2020, 03:15 PM | #4 |
All about them K’s
This, if your 4.5 inches out I doubt you’ve gotten in far enough to be fighting the spider gears, sometimes it takes a little wiggling/rotating to get it back into the bearing.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
07-26-2020, 03:44 PM | #5 |
Thanks, when you say check the spiders what should I look for and what should I do? I have zero knowledge of the working or a rear.
Thanks again. |
07-26-2020, 04:02 PM | #6 |
wiggle it up and down with your man hands, it should slip right in..
use the palms of your hands, fingers bent out and away and shove it home.. even full floaters this size go in the same way good luck!
I started out with nothing - and I still have most of it |
07-27-2020, 02:32 PM | #7 |
Thanks for the help, I stayed with it and my problem was I didn’t tilt the axel up high enough, (I think, I’m not pulling it out again to find out, haw), Thanks Again.
07-27-2020, 08:07 PM | #8 |
All about them K’s
Don’t worry we’ve all probably been there a time or two. Glad you got it back together.
07-28-2020, 11:21 PM | #9 |
Try spelling it "axle" and see if that helps
