Old 07-26-2020, 08:59 PM   #1
BigTruckDriver
BigTruckDriver's Avatar
Lowering rear 1.5"?
What are my options with the least amount of modifications? Not looking to cut bed support for a 2" shackle.
BigTruckDriver is offline   Reply With Quote
Old 07-26-2020, 09:25 PM   #2
sweetk30
sweetk30's Avatar
Re: Lowering rear 1.5"?
drop springs or drop hanger for the front spring eye location.
i did mine with the drop hanger and shackle to get it dialed in . i just moved my hanger up and re-drilled the holes and used 7/16 bolts with stover / crimp lock nuts . then the rear i did have to notch the crossmember on the box for the shackle .
but mine i went down 2.5" front and rear . so if you did just hanger in the rear at the front of the leaf spring you will prob be fine i think . just be sure to check pinion angle .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 07-27-2020, 09:24 AM   #3
bigblock73
yeller
bigblock73's Avatar
If you have the longer HD springs, a drop shackle will clear the bed support. The shorter LD springs are the ones that will interfere with a drop shackle.
bigblock73 is offline   Reply With Quote
Old 07-27-2020, 12:25 PM   #4
sweetk30
sweetk30's Avatar
std issue is 52" eye to eye .
hd is the 56" eye to eye . and its 4" longer on the back side only .
and the shackle hanger bracket is back 4" in the extra frame holes . most i have seen have the extra frame holes already there .
Old 07-27-2020, 01:57 PM   #5
bigblock73
yeller
bigblock73's Avatar
You are correct.
Old 07-27-2020, 09:40 PM   #6
BigTruckDriver
Looks like drop leaf springs are going to be my best bet. I am also looking to pull a trailer . Any reputable place to purchase from?
Old 07-27-2020, 10:16 PM   #7
MikeB
MikeB's Avatar
Problem with just doing raised hangers or longer shackles (and not both) is the pinion angle will change and you will need angled spring shims to raise or lower the differential nose. if I had a do-over, I'd go with lowered springs.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
