Old 07-28-2020, 11:39 AM   #1
lowrodderchev
lowrodderchev's Avatar
Cut harness
I picked up a LS motor teams for a swap on my 68 burban but the wiring harness that goes into the firewall was cut am I still able to use it?
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 07-28-2020, 12:14 PM   #2
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: Cut harness
Take a picture, what year did the motor come out of?
More specifics will get you more advice
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 07-28-2020, 12:19 PM   #3
lowrodderchev
Re: Cut harness
2000 chevy truck my phone won't let me attach pix for some reason harness was cut on right side of steering in engine compartment
Old 07-29-2020, 09:12 PM   #4
Dustytrix
Re: Cut harness
It still depends on which wires were cut. The ecm is located where you are describing. If they are a lot of pinks that are cut there you ok. Really need to trace wires from each sensor connector back to ecm, if they are intact you are good. The rest are usually spliced to make a standalone anyway.
Dustytrix is offline   Reply With Quote
Old 07-30-2020, 04:56 PM   #5
aknovaman
Re: Cut harness
The only LS truck EFI harness that goes through the firewall is from the TACC module (if applicable). All the EFi wires are attached to the bottom of the fuse panel and a few other connectors that connect to the under hood chassis. Can you post pics?
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 07-30-2020, 09:06 PM   #6
87chevy.com
Re: Cut harness
Try fixing the phone and photo problem, so again, you get the best recommendation
