07-31-2020, 03:20 AM | #1 |
Exhaust trailing arm hole question
Is a 3 inch hole to drill into the trailing arm crossmember for 2 1/2 inch exhaust enough? I bought a 3 inch hole saw but it looks quite small but I want to make sure before I start drilling my crossmember.
Posted via Mobile Device |
07-31-2020, 09:07 AM | #2 |
Re: Exhaust trailing arm hole question
I used a 4" hole saw on mine just to make sure it had enough clearance. I did add a 1/4 plate to make it stiff.
07-31-2020, 09:17 AM | #3 |
That's tight , I used 4" for 2 1/2" pipes and it was a lot easier to mark the hole location and use a cut off wheel to cut thru the cross member and get a tight fit on a short section of pipe to weld in to place , The 4" pipe came from Metal supermarkets and they cut and shipped it to me for less $ than I could have driven there to get it across town .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
07-31-2020, 12:29 PM | #4 |
They also have bolt-in kits out there for simplicity if that helps....
https://azproperformance.com/collect...outs-63-72-c10
07-31-2020, 04:57 PM | #5 |
I cut mine with a 3.5" hole saw and reinforced with a flat plate of steel 3/16" with a 3.5" hole cut in it.
07-31-2020, 05:23 PM | #6 |
I used a 3 1/2 hole saw on mine. Unless you are going to have 500+ HP you don’t need to reinforce it.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
08-01-2020, 12:47 AM | #7 |
I would say re enforce the hole for a professional fit and finish
08-01-2020, 04:51 PM | #8 |
My frame was bare when I cut the holes for the exhaust so it was easy to do. I didn't know what kind of strength I removed when I made the hole so the reinforcement plate seemed like a good idea and I kind of like to do fab stuff. My LS1 did 380 rwhp on the chassis dyno so about 450 at the crank?
