Rag Joint Replacement
Okay, yes I did a search and was left even more confusedl...
![]() Took me a while of searching just to figure out what the silly thing is called. My Rag Joint has disintegrated. I replaced the steering column and joint with one from a '65. Worked for a day and also came apart. Does anyone know where I can get one of these (new please)? Application: 1966 Chevy C-20 Power steering Power brakes auto 350 (crate replacement) |
Re: Rag Joint Replacement
Um... my truck is a '66. Weren't there changes to the column in '67? Some kind of slider?
Seriously? Maybe do a web search for your year truck.
I did. Thanks for the suggestion though. Almost all of the joints available are for '67-on. So, being a general ignoramus on this kind of thing, I started this thread hoping for some relief from confusion and frustration. Maybe someone who knows if a '67 joint will work would hopefully let me know. I have little enough to spend on this project and was rather hoping not to waste money on useless parts.
Moderator
![]() ![]() Join Date: Aug 2011
See post 5.
Moderator
So the rag joint normally is attached to the steering box.
One end is splined? What diameter and how many splines are there on your box? What diameter and configuration is the other (shaft) side? 3/4" Double D?
You can probably rebuild your exisiting rag joint using a newer one, just take them apart and reassemble using your original metal bits. Did that with my nova long before rag joints where readily available everywhere.
#9 | |
Moderator
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 08-08-2020 at 03:27 PM. |
You can buy a rebuild kit.
Grind the heads off the existing rivets. Replace the fiber disk. Assemble with bolts and lock-nuts to replace the rivets. Time consuming grinding off the old rivets but not hard and very cheap too. |
![]() ![]() Join Date: May 2015
If you have a nearby napa or maybe other quality parts store, there are rebuild kits...you could take what's left of yours and see how close it matches....
https://www.napaonline.com/en/p/NDP6...iABEgI9BfD_BwE
