I found long tube Headers that fit!
I stumbled across these on Speedway Motors.They’re made for sbc engines mounted in an early Ford chassis, but as I looked them over I thought they just had to fit the AD frame and I was right! I was worried about the steering shaft but it clears with ease on my trial fit. They sell them ceramic coated or raw steel. You can see them here:
https://www.speedwaymotors.com/Small...ted,39132.html
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. Last edited by mobileortho; 08-19-2020 at 10:44 PM. |
Re: I found long tube Headers that fit!
Slick. Those look to be a real problem solver.
I mostly lurk here trying to soak up and glean as much knowledge as I can. I hope to be able to contribute in the future.I have a '54 GMC with a Chassis Engineering front suspension. I still have a long way to completion. I'm in the middle of relocating to a new state so the pickup is on hold for now. However, this is good news, as I really didn't want to use stock exhaust manifolds.
Mobileortho, if these work, you're my hero. Rich |
I was reading through the reviews on Speedway, have you noticed a difference in height difference from bank1 to bank2 ? A reviewer or two said the pass side sits about an inch lower to the ground. Just wondering if you noticed it.
#5 | |
I saw that as well. I haven't mounted the passenger side yet as I was more concerned about clearance for the steering shaft. Hoping for some garage time this weekend to see.
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
I test fitted the passenger side and it appears that is the case. My guess it’s that was to give some extra clearance for the starter? Not sure how a a stock starter does, I’m running a mini and have tons of room.
