08-25-2020, 03:03 PM | #1 |
Looking for a good carb rebuilder
My local guy has shut his doors. Been there since the 50s can't blame him he was in his late 80s . But like its says need someone to rebuild my carb not exchange as it looks to be the original on my 68 327 .
One I have looked into is Carburator USA in New Jersey. Seems like they have a good reputation but I'd like to hear some opinions and options .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 08-26-2020 at 04:55 PM. |
08-25-2020, 03:34 PM | #2 |
Moderator
Re: Looking for a good carb rebuilder
The best carb rebuilder is you. You will go slow, make sure everything is perfect. Clean each part. Set floats perfectly. Use the correct matching gaskets. Put check balls where they're supposed to go. Give it a try, you'll like it.
08-25-2020, 04:01 PM | #3 |
I was about to say the same thing haha. You'll know its been done right if you do it yourself.
72 C10 lwb fleetside -stock 350/350 combo |
08-25-2020, 04:10 PM | #4 |
I used to do them all the time. But when carbs get to old they sometimes need to be more than rebuilt. The guy I knew used to recoat the metal so there was no porosity . The place in Jersey does the same.
A frankly I dont like doing it.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
08-25-2020, 04:13 PM | #5 |
If you truly can't or don't want to do it yourself, call Cliff www.Cliffshighperformance.com (1-740-397-2921) Cliff does NOT build carbs any more. He IS selling parts though. I got a kit and some parts 2 weeks ago. When you call him, CLiff WILL be the one answering the phone.
Quadrajetpower.com is THE ONLY company that Cliff endorses for car rebuilding work. There may be another coming soon. You'd have to talk to Cliff about this new builder.. DO NO, DO NOT EVER trade your original carb in for a core, if you go another direction, EVER... |
08-25-2020, 05:58 PM | #6 | |
Who Changed This?
Also, Ken at https://www.ebay.com/str/everydayperformancellc
08-25-2020, 06:41 PM | #7 | |
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs |
08-25-2020, 06:44 PM | #8 |
Bob Stone at the carb Dr. Is the man.. Restores them versus rebuilding
They are a work of art when done |
08-25-2020, 07:41 PM | #9 |
Give Jon at the carb shop a call. He does kits etc and may still offer rebuild services. A lot of folks with older vehicles ( back into the teens use him)
http://www.thecarburetorshop.com Jeff |
08-25-2020, 10:11 PM | #10 |
Old member
I have a guy here local in SC that has been building carburetor's his whole life. He even spent time with some of the famous NHRA dragster teams building them. He does them at his own shop.
He took my Edelbrock carburetor that the shaft was loose and fixed it. Elelbrock doesn't have a kit for it. The throttle bore linkage was leaking, it was worn out. He took it a part and made me a set of bushing's and put it back together. It ran great! He has my Ramp truck carburetor now doing a complete rebuild on it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
08-26-2020, 08:50 AM | #11 | |
I mentioned Cliff, because he's the Quadrajet master. He has parts made that no one else offers. His accelerator pump seals are ethanol resistant, others may claim such, but are likely NOT. Cliff can sell someone needing a Quadrajet refurbished, ALL the parts needed, Jets, metering rods, what ever. He can tailer your rebuild with the EXACT parts needed for your specific engine, AND get it right on, the first time. Getting your carb built for your specific engine/vehicle is NOT something a lot of builders can do. It's good to hear many that have had good results with other builders. I hear many folks going to this new, self adjusting fuel injection. I wouldn't have anything to do with it. A properly built and tuned Quadrajet will out perform those units, every time, and no need to completely rebuild a fuel system!!! Mark, Just a thought... Find someone to do the work, see if they will let you buy the parts. Get ALL the parts from Cliff, including the shaft bushing kit. Last edited by 68Gold/white; 08-26-2020 at 10:12 AM. |
08-25-2020, 11:59 PM | #12 |
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
08-26-2020, 06:56 PM | #13 |
Business must be slow at a shop I use, suddenly the owner wants to rebuild my carb. The carb works quite well as is, but what the heck, it's kind of a project. You should see this guy's shop, clean as a whistle. He's setting me up with a divorce choke as well -looking forward to it.
A childhood friend has worked for him 45 years now, amazing to me. He's short and skinny, you should see him on the "diving board" above an engine compartment. He's a surgeon and everything spotless. The shop gets the maiden start on my C10.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
