08-30-2020, 09:23 PM | #1 |
Pertronix on 72
Can I put a pertronixs electronic ignition on my 72 -350 with the stock alternator and voltage regulator ? Or will the original alternator and external voltage regulator not supply enuff power ?
08-30-2020, 10:40 PM | #2 |
Re: Pertronix on 72
You should have plenty of power, but will need to remove the resistance wire and bump the supply voltage up to the full 12 volts.
Jim |
08-31-2020, 12:00 AM | #3 |
70+ ( Old Skool Club )
Re: Pertronix on 72
I put a Petronix complete distributor and 50k coil on my stock 72 C10 with 350 and auto trans, 4 years in no issues except tach doesn't read right but pretty sure that's a tach issue. Which resistance wire you talking about?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
08-31-2020, 12:31 AM | #4 |
Re: Pertronix on 72
Thanx for the replies
08-31-2020, 02:47 PM | #5 |
Re: Pertronix on 72
The wire from the firewall bulkhead to the factory coil was a resistor wire on my 72. I think it is meant to drop the voltage to prevent burning up the points. It took me a couple of years, a couple of carburetors, and a whole lot of head scratching to figure that one out (pre-internet days).
08-31-2020, 08:55 PM | #6 | |
Re: Pertronix on 72
09-16-2020, 08:16 PM | #7 |
Re: Pertronix on 72
Sorry for the late response. It would backfire up though the carb when you hit the gas hard off idle.
09-01-2020, 10:20 AM | #8 |
Re: Pertronix on 72
I had another truck that I did an HEI upgrade on without knowing about that wire, and kept killing modules. Also, with lower voltage, you're not getting all the spark power available with the new set up
Jim |
09-01-2020, 01:55 PM | #9 |
Re: Pertronix on 72
After I bought my truck I learned that the previous owner installed an HEI still using the resistance wire. The resistance wire was blank metal because the insulation burnt away the whole length of the wire. The wiring harness was toast. If using the original resistance wire when using HEI, there is a good chance for fire in the engine bay.
09-16-2020, 09:00 PM | #10 |
Re: Pertronix on 72
I put a pertronix on a 74 F-350 and had to wire directly from the ignition switch to bypass resistor wire. Worked like a charm.
1969 GMC K25 2007 Chevy 2500HD Classic Duramax 1999 Tahoe 2DR 4WD Base Model 5.7l |
09-16-2020, 09:06 PM | #11 |
Re: Pertronix on 72
What he said.
09-17-2020, 08:46 PM | #12 |
Re: Pertronix on 72
Yep, that was a tough lesson for me... This was back in the late 90's and I had no idea about the resistor wire. Changed carburetors about three times, pulled timing cover to check cam timing, all kinds of stuff. Then one day I overheard the guy at the local speedshop telling a customer about the resistor wire. I replaced mine from the bulkhead plug to the coil and it fixed it. I think it was a red wire that actually said resistor on it.
09-17-2020, 08:50 PM | #13 |
Re: Pertronix on 72
I knew about the resistor wire, and I checked when I installed the Pertronix. The wire had in excess of 11 volts so I thought I was good. I completely over looked the fact that the AC could pull the voltage down.
09-20-2020, 11:06 PM | #14 |
Re: Pertronix on 72
Put the pertronics in , no issues , put to 12 volts too, thanx for the replies guys !
09-21-2020, 01:32 AM | #15 |
Re: Pertronix on 72
It will work fine, but you might want to consider an electronic voltage regulator if your truck has a separate voltage regulator, not inside the alternator. They hold the voltage more constant than the mechanical relay type, and that's always better for electronics. Auto Zone sells a good one:
https://www.autozone.com/batteries-s...715/130005_0_0
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. Last edited by Bob B.; 09-21-2020 at 01:38 AM. |
11-18-2022, 12:02 AM | #16 |
Active Member
Re: Pertronix on 72
11-18-2022, 02:24 AM | #17 |
Re: Pertronix on 72
I put a small cap, mechanical tach. drive H.E.I. in my buddie's '64 Corvette several years ago. Looks stock, seems to work good, & wasn't much money on ebay. Non tach. drive ones are cheaper yet.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
