09-03-2020, 05:32 PM | #1 |
64 C20 clutch spring length and fork pivot clip
We're moving forward and hope to get the ol' boy started this weekend.
We ordered parts from LMC to rebuild the Z bar and lower clutch linkage. My questions are as follows, -How long is the clutch return spring from the fork to the frame supposed to be? The one sent is straight at one end. -As I didn't realize the clutch fork needed a clip to retain it to the pivot in the bell housing, can I remove the fork to install it without having to pull the tranny? As always your replies and insight are greatly appreciated. Regards, Desert dog Still roasting in Tucson |
09-03-2020, 07:51 PM | #2 |
Re: 64 C20 clutch spring length and fork pivot clip
You should be able to just pop the fork off without pulling the tranny. With no clip on, it will probably come off pretty easy
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
