09-04-2020, 11:28 AM | #1 |
A couple of transmission questions
I'm working on my project 70 this morning and I was wondering what this sensor looking thing is behind one of the shift arms. This is a 3/speed manual. Also what transmission do I have? I have heard Saginaw or Muncie. The truck is a V8 350 with 3 on the tree. Jere are all the markings on the case.
Thanks! |
09-04-2020, 11:47 AM | #2 |
Re: A couple of transmission questions
Seeing that it is in the front of the case I would take a stab at it being for emissions indicating shifting into final gear for the vac advance to work.
How many bolts holding on the side cover |
09-04-2020, 01:11 PM | #3 | |
That ‘sensor’ is actually a ground switch. Completes the circuit for the switch up on the intake manifold. If you’re not using it leave it there. The thread on it is unique and a normal plug won’t fit and seal. |
09-04-2020, 03:16 PM | #4 | |
09-04-2020, 03:18 PM | #5 |
There are 7 bolts holding the side cover not counting the two bolts for the shift arms.
09-04-2020, 03:45 PM | #6 |
That’s a Muncie.
Saginaw also has seven bolts. Easy ident is bolts on cover position. Sag has one bolt in the centre top, Muncie has 2 spread apart close to the corners. |
09-04-2020, 04:37 PM | #7 |
