Old 09-05-2020, 02:17 AM   #1
pjmoreland
pjmoreland's Avatar
Correct Fasteners for 67-68 Grille Center Support
A previous owner of my truck cut the center horizontal bar out of the grille and zip-tied a portion of a 71-72 grille in its place. I am in the process of returning it back to stock. The two smaller fasteners that attach the grille to the center support under the latch are missing. It looks like 1/4 or #14 screws would fit through the holes, and I'm assuming clip nuts need to be installed on the grille. I'd like to get as close to stock as I can. What size and type of fastener was on there originally?
pjmoreland is offline   Reply With Quote
Old 09-05-2020, 08:57 AM   #2
Davidf
Re: Correct Fasteners for 67-68 Grille Center Support
U or J-nuts on the grille support for sure. I used black hex head screws.
Davidf is offline   Reply With Quote
Old 09-05-2020, 02:32 PM   #3
pjmoreland
pjmoreland's Avatar
The problem with U or J-nuts is that the bend in the grille where the nut would go is too short for a standard J-nut. There must have been a very short clip on there originally. I guess I will trim down. A U-nut.
Old 09-05-2020, 06:03 PM   #4
Davidf
The J-nut goes on the center support.
Old 09-05-2020, 06:09 PM   #5
pjmoreland
pjmoreland's Avatar
That seems super awkward for accessing the screws. Are you sure that's the way it was from the factory?
Old 09-05-2020, 08:45 PM   #6
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
https://www.lmctruck.com/1967-72-che...-for-chevrolet Pan down to the bottom of the page. Numbers 17 and 18 are what I believe you need...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 09-06-2020, 05:14 PM   #7
pjmoreland
pjmoreland's Avatar
Since it says quantity 6 needed, those u-nuts are probably larger (5/16) for along the bottom edge of the grille, although there are actually only four used, as the outer two are welded on nuts.
