cross member
Hi All
I have been doing a engine and transmission swap in my 65 SWB C10 (454 & turbo 350) and I am getting ready to install the engine and trans. The question is I have read that the cross member that supported the manual transmission/mount should be removed. Can anyone tell me if this true or point me in the right direction. Thanks |
![]() Join Date: Sep 2006
Re: cross member
You should remove the cross member that was holding the transmission bell housing.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
![]() ![]() ![]() Join Date: Jan 2018
Re: cross member
Yes, when switching from a manual to an automatic, the manual trans mount crossmember needs to be removed. The auto won't fit with the crossmember still there
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Re: cross member
Thank you for your help
Tags |
454 swap, 65 c10, cross member, disc brake conversion, th350 installion |
