Old 12-15-2003, 04:17 AM   #1
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
Huck, a solution for you
Huck, i was looking on paces site. heres a speedo conversion that will for you or anyone else for the matter. It takes a electronic signal from your tranny and then runs a speedo cable that will work in our trucks.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 12-15-2003, 04:18 AM   #2
stelth2002
stelth2002's Avatar
Forgot the link.... here t is http://www.paceparts.com/product.asp?3=166918
Old 12-15-2003, 05:21 AM   #3
72addict
I know that the 700r4 trans was made with both mechanical and electronic speedos, so the parts are available for the conversion for the automatic. I have also replaced the speedo gear with a shudder wheel in a np205 tcase swap I did. The inside splines are exactly the same, so it was a dirrect swap. My point is, see if the trans you are running was produced prior to the electronic speedo ('87 and down I think). Even if not, the sensor ring will probably be a dirrect swap with a speedo pickup gear. Then you would need to modify the tailhousing (if it has one) to accept the speedo cable. It helps if you know a machinist for this. It may be cheaper than $280
1957 Cameo
72addict is offline   Reply With Quote
Old 12-15-2003, 05:53 AM   #4
stelth2002
stelth2002's Avatar
huck is using a nv4500. they dont any provisions for a mechanical hookup. He hasnt been able to find out how to get his speedo to work yet.
Old 12-15-2003, 08:03 AM   #5
72addict
This site shows what I mean
www.autotransinc.com/ 4l80hous.htm
1957 Cameo
Old 12-15-2003, 08:04 AM   #6
72addict
www.autotransinc.com/4l80hous.htm
1957 Cameo
