Old 09-19-2020, 06:42 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Plasti Dip for wire harness retainers etc.
Anyone try this stuff or similar? Supposedly it does well under extreme temps. Seems ideal for these, as a start.https://www.youtube.com/watch?v=6fuIjaXSCxk
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 09-19-2020, 07:20 PM   #2
dmjlambert
dmjlambert's Avatar
Re: Plasti Dip for wire harness retainers etc.
I would try it, it seems like a good idea. Is that a wire bundle clip? Where did you find that?
Old 09-19-2020, 11:34 PM   #3
71CHEVYSHORTBED402
It's one of the clips used for the intermediate and rear wire harnesses. I think 13 total. Just speaking for my truck, the clips along the frame rail were tan rubber/plastic coated, and the ones along the rear bed support were black coated. I figure all black is good enough
https://www.classicparts.com/1947-72...ctinfo/52-905/
Picture of original too
Tony
Old 09-19-2020, 11:57 PM   #4
davischevy
davischevy's Avatar
I have been using it for years. It works, but you may have to double dip to get a similar thickness that came from the factory.
I have a spray bomb of it also. It takes several coats to replicate the factory finish.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 09-19-2020, 07:40 PM   #5
CG
BlahBlahBlah
Thats a good idea. Ive used plasti dip on tool handles quite a bit, never considered using it like this.
Old 09-20-2020, 12:24 AM   #6
jimijam00
why bother?
jimijam00 is offline   Reply With Quote
Old 09-20-2020, 12:28 AM   #7
'68OrangeSunshine
'68OrangeSunshine's Avatar
Originally Posted by jimijam00 View Post
why bother?
So the metal edges of the clip don't chew into the insulation of your wiring in extreme conditions.
Old 09-20-2020, 10:14 AM   #8
CG
BlahBlahBlah
Plus I think a lot of fellas like to add that extra detailing touch. Sometimes I see our trucks all done up all nice, but some small brackets, or nuts etc were never touched up. They really stand out when the rest of the truck looks so good.
Old 09-20-2020, 11:51 AM   #9
chewychevy67
Works for the spark plug wire Retainers as well.
chewychevy67 is offline   Reply With Quote
Old 09-20-2020, 10:16 PM   #10
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I used it for the same purpose
Old 09-27-2020, 01:38 AM   #11
71CHEVYSHORTBED402
Yep. I'm half tempted to dip the entire thing, perhaps more kind to the frame That said, what you did looks exactly original. Looking forward to seeing how the battery cable retainer comes out too, should be nuts.
Tony
Old 09-27-2020, 05:40 AM   #12
OregonNed
OregonNed's Avatar
That is a pretty cool. I can think of a few things I'd like to try too..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 09-27-2020, 12:56 PM   #13
davischevy
davischevy's Avatar
We need a new thread on uses for baling wire.
Zip ties are the new baling wire, but you can't hang parts from them.
other Larry
Old 11-29-2020, 11:24 AM   #14
71CHEVYSHORTBED402
Velcro I use it often for this & that around the house, but can't hang auto parts from that either.
If I remember right the old timers all said WD-40, duct tape and bailing wire. They neglected to mention vinegar, IMO
Tony
Old 11-29-2020, 12:09 PM   #15
Getter-Done
Getter-Done's Avatar
I miss this thread some-how.
I really like Plastic-Dip.
I have used it on many projects.
Double dipping as already mentioned makes for great results.
And I also like the Liquid tape product .
I use it on my wiring projects.
You could probably use this to touch-up the plastic dip?
Three coats is best for this stuff.
Link:https://plastidip.com/our-products/liquid-tape/
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 11-29-2020, 06:46 PM   #16
vics stuff
I have been using plastic dip for other projects as well. Just thinking outside of the box.
Vic
vics stuff is offline   Reply With Quote
