09-22-2020, 12:48 PM | #1 |
1949 Chevy w/292
I'm installing a Chevy 292 in a 1949 Chevy 1/2 ton. Does anyone know where I can get rear engine mounts for this setup? I'm looking for mounts that go between the bell housing and the crossmember. The bell housing connection site flares up which matches the angle of the crossmember. Thanks
Wayne |
09-22-2020, 02:00 PM | #2 |
Moderator
Re: 1949 Chevy w/292
First of all Great to see you on this site.
Maybe Aspen Parts in Arizona. Or, if you were a paying member you could place a request in the for sale section of the 60-66 parts, someone would surely have one there. From the site rules: "As always a basic membership on the forum comes with no charge. You may post a reply in any of the Classified Forums. You will not have the ability to offer items "For Sale", "For Trade", or make a "Wanted to Buy" or "What's it Worth" post."
09-23-2020, 06:37 PM | #3 |
Thanks for the info
09-29-2020, 08:39 AM | #4 | |
This is all just a thought but if you go to the top of the home page and click on search you can put in anything you want information on and do some research. Which ever way to do it it will be a much better truck, good luck. Being as how you are new to this site, you would benefit if you were to pay the $25.00 annual fee to join as mentioned earlier, there is a vast knowledge here on this site available to you that way. I believe you may have to join also to use the search. Good luck. Last edited by old51sedan; 09-29-2020 at 08:44 AM. Reason: more information |
09-29-2020, 01:53 PM | #5 | |
The $25 is a yearly payment to join in as a supporting member of the site. Supporting members have a few more perks than registered users. Check out this thread for all the info about the ins and outs of membership. http://67-72chevytrucks.com/vboard/a....php?f=93&a=17
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
10-01-2020, 01:52 PM | #6 |
I have a 5 speed Tremec. I think I'll be going with biscuit mounts that will go between the crossmember and the bellhousing. To achieve a 3 deg. pitch there's about a 1 1/2 inch gap between the two surfaces. Thanks for the help
Tags |
1947-53 chevy truck, chevy 292, rear motor mounts |
