12-15-2003, 04:30 PM | #1 |
egr valve
what yr did chevy trucks start having an egr valve? i am looking around at trucks right now and want one that doesn't have an egr valve or cats
thanks |
12-15-2003, 04:46 PM | #2 |
Robert Olson Transport
my 86 with a 4.3 has no cats i know for sure i dont remember having an EGR either
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
12-15-2003, 05:42 PM | #3 |
You in AZ?
Not sure what year, I think it may have changed depending on what state the truck was for. Someone could probably answer better. There is a sticker under the hood near the hood latch. The sticker shows what emissions equipment should be on that truck. Something to look at when buying a truck. This sticker is the same thing the inspectors look at here in AZ for visual inspection during emissions testing. If you are trying to stay away from as many emissions components as possible get a '73-'75 ?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
12-15-2003, 05:45 PM | #4 |
My 1975 3/4 ton heavy duty with 350 has no EGR or cats in Cal, but I have A.I.R.
Light duty (1/2 ton) have EGR and cats. AR
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
12-15-2003, 08:20 PM | #5 |
what is this A.I.R. system u speak of?
12-15-2003, 08:30 PM | #6 |
AIR is the air pump that pumps cold air into the exhaust
i stand corrected tho my 86 has an EGR in it although it is broken and my air pump isnt operating either i figured that id fix it in march when i need to get past emmissions unless i can get someone to overlook it
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! Last edited by old Rusty C10; 12-15-2003 at 08:34 PM. |
12-15-2003, 08:57 PM | #7 |
i guess i should focus my search to 73-75
i really don't want cats and if i don't have to have egr i could do without that also, but i still need to pass emissions. thanks for the help |
12-15-2003, 09:15 PM | #8 |
Professional Grade
My 1980 3/4 ton doesn't have the AIR system, but does have an EGR valve, I actually want it on there so the engine heats up a bit quicker...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
12-15-2003, 10:17 PM | #9 |
Emission controlls such as Catalitic Converters , EGR and A.I.R. were determend by GVWR, gross vehical weight rating. I know in 1977, Pickup Trucks with GVWR under 6400 lbs. had Emission Controlls. Trucks over 6400 GVWR had none. I believe it was the same for 1978, but after that, started putting controlls on trucks under 6400 GVWR.
12-15-2003, 10:27 PM | #10 | |
1973 to 1975 tucks did not have cats, some of the under 6400 lbs. GVWR may have had EGR valves. As far as passing Emissions tests, you have to meet the Emission Standards that were in place for the year of your vehical i.e. 1974 truck must meet 1974 Clean Air Standards. |
12-15-2003, 10:41 PM | #11 |
About the only place you need to worry about emissions on anything older then 78 is the Republic of Kalifornia on a Cal emissions truck. I know a Cal 1/2 ton truck was running EGR in 74. Waxer over at CK5 had a hell of a time getting his 74 K5 past emissions. Ended up having to change intake manifolds and some other junk. I hear that some 76's had Cat's there as well. The rest of the country didn't get cats till 78 or later. My 75 doesn't have anything but a PCV valve. Not even a canister. My 79 had no Air junk but did have cat's, Evap, restricted fill neck, Thermac.
Now EGR's were used by GM well before the emissions crap. My 70 Burb had a 64 327 with EGR. EGR is not the evil monster everybody thinks it is. In a higher compression motor it helps control detonation. I had a hell of a time getting my 75 to quit pinging. I was ready to drop a EGR intake on it. I ended up having to run it a little wet and back out of the timing, Get it freash air (it had the restrictive under hood aircleaner with no Snorkle) by throwing a 85 Aircleaner on it with a snorkel. Whay did I have such problems?....THe motor was setu up for leaded fuel. Leaded fuel is less prone to detonation.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
12-15-2003, 10:45 PM | #12 |
You get what you pay for
No 327's ever made came with a EGR. Some must have stuck a later year EGR intake on that thing.
But I do agree, with a EGR, you can run more timing.
Mike 1985 Chevy C-10 |
12-17-2003, 02:23 AM | #13 | |
5 day ban, learn to behave.
mike |
12-17-2003, 11:32 AM | #14 |
As far as I know, the only thing different in a leaded fuel motor and non, is the valve seats.
12-17-2003, 01:28 PM | #15 | |
The EGR actually can help becuase it pumps a little no oxygen gasses in there. Sound counter productive I know but it helps raise the flash point enough to stop ping and let the ignition be all spark plug.
12-18-2003, 04:04 PM | #16 |
what do you hook the vacuum to on the EGR. i am getting a new tomarrow and need to know, PORTED or MANIFOLD
2004 Silverado Crewcab (Dark Spiral Gray) |
12-18-2003, 06:45 PM | #17 |
Ported. You only want it working above idle.
12-18-2003, 06:53 PM | #18 |
Did someone say MUD?
I have a 78 3/4 4X4 (Arizona Truck) and it never had cats or egr or AIR Injection
Im in the market guys...so keep ya eyes peeled -------------------- Mini trucks are for guys who cant get it up! |
12-18-2003, 07:15 PM | #19 |
My 78 blazer has nothing on it (cats, egr, air) its a 1/2 ton originally had a 400 in it but i haven't got it to the point of taking it in for inspection hopefully it passes, I think it shoud with the new engine, i'm thinking it probably will only be street legal for the first year anyway.
2011 CCSB GMC 2500HD DMAX 73 GMC 3/4 ton 4x4 96 Chevy 1500 STD Cab Shortbed Z71 Owner of WickedWolfRC.com |
