09-26-2020, 09:47 PM | #1 |
At the body shop.
700r4 TV cable
454 quadrajet 700r4
Needs a proper tv cable bracket. The hokey extension is just that. Whats a better way?
" That didnt make it any newer " " Dont antique the equipment " |
09-26-2020, 10:31 PM | #2 |
Re: 700r4 TV cable
A proper cable ,they come in different lengths .They allso make a universal cable that you can adjust the crb end that works pretty good .
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
09-26-2020, 11:21 PM | #3 |
At the body shop.
Re: 700r4 TV cable
For what application?
I dont see any length differences except overall length.
09-27-2020, 07:05 AM | #4 |
Re: 700r4 TV cable
Takes a bit of trial and error to make your own, but worth it. Make a pattern out of cardboard or thin plastic. Then find a piece of metal that works for you....I drilled a couple holes before getting the tension correct. Spacer or washers to level out the uneven carb side plate. I will post the new inproved 4bbl version later.
09-27-2020, 12:25 PM | #5 |
Re: 700r4 TV cable
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 Last edited by kaycee; 09-27-2020 at 12:30 PM. Reason: delete |
09-27-2020, 12:27 PM | #6 |
Re: 700r4 TV cable
https://www.amazon.com/700R4-TRANSMI.../dp/B01G981A5A
Heres one that I used have had no problems you adjust the length with the nut behind where it attaches to bracket once the length is set you adjust the tightness of cable ,very easy to set up.
