Old 09-27-2020, 12:23 PM   #1
86swb
Born a Chevy Man
86swb's Avatar
Ethanol free gas in our trucks
I have been told it is best to use Ethanol-free fuel in our trucks. Does anyone know if this is true and why?
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 09-27-2020, 01:03 PM   #2
Dead Parrot
Re: Ethanol free gas in our trucks
Anything made after the early 70's should be good for up to 10% booze. That is when they started the ethanol thing and mandated that vehicle fuel system be 10% alcohol compatible.
If it is going to sit for many months between being ran, then best to use 100% gas. The alcohol wants to absorb water, if not water already in the tank then from the air in the tank. If 100% not an option, fill it up before parking it.
Unless you have a special 'race car' type alcohol/methanol fuel system, avoid anything higher then 10%. The Flex Fuel stuff is up to 85% and the EPA gave its OK for 15%(think corn lobby) over the objections of vehicle makers and most refiners.
Dead Parrot is offline   Reply With Quote
Old 09-27-2020, 03:44 PM   #3
Corts60
Just here to tinker
Corts60's Avatar
Agree with above. Ethanol attracts water and the water will eat at the aluminum parts in your carburetor, etc. Also, the ethanol likes to eat older rubber hoses and such. You can change out all your rubber with modern compatible material and be just fine.
Old 09-27-2020, 04:44 PM   #4
Will they run with it, yes. But most of our stuff sits a good bit and that is where the EVIL of ethanol comes in and does it's damage to hoses and some other parts. I run it in mine when I am out of the local area, mostly cause I have to, but then I fill up with non-ethanol when I get home and run the other stuff thru. Mine gets used enough that I don't think it will be much of an issue.
Old 09-28-2020, 09:43 AM   #5
93M6Formula
I always run ethanol free, even in my modern vehicles.
1982 Sierra Classic K15 RC/LB 6.2L Diesel 700R4
1988 GTA Trans AM 305 TPI 700R4
1993 Formula Firebird LT1 T56
1995 GMC K2500 ECLB 6.5L 4L80E
1996 GMC K3500 CCLB LB7 6L90
93M6Formula is offline   Reply With Quote
Old 09-28-2020, 10:32 AM   #6
86swb
Born a Chevy Man
86swb's Avatar
Thanks for all the replies. I think I will try it and see what happens.
Old 09-28-2020, 10:45 AM   #7
jayoldschool
Moderator
I run ethanol-free in all my carbs. Only because they sit. On a daily, ethanol is fine.
jayoldschool is offline   Reply With Quote
Old 10-07-2020, 01:31 PM   #8
Jeepwm69
This. My 83 GMC, and my two 85 Jeep CJ's get ethanol free, not because they won't run ok on E10, but because they don't get driven a lot, and pure gas lasts MUCH, MUCH longer than E10.
If you drive it daily, doesn't matter.
If it's seldom driven, use pure gas.
Jeepwm69 is offline   Reply With Quote
Old 10-01-2020, 06:37 AM   #9
cadillac_al
I have been running ethanol in everything for over 30 years. My cars, trucks, bike and sleds don't mind it. I wouldn't pay extra for a benefit that I don't seem to need.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 10-01-2020, 08:57 AM   #10
86swb
Born a Chevy Man
86swb's Avatar
Mine sit for weeks at a time and was told Ethanol-free would be better. Yes, Ethanol-free is more expensive but was told it would better to be safe. Sometimes I go months and do not drive them but I do start and run the engine at times.
Old 10-01-2020, 04:16 PM   #11
Tom
driving is in my blood
Tom's Avatar
That statement can be applied to literally every vehicle ever made. It's always better.
Old 10-01-2020, 05:23 PM   #12
69Tom
69Tom's Avatar
There doesn't appear to be too many places selling it in the Phoenix area. Which do you use?
69Tom is offline   Reply With Quote
Old 10-06-2020, 03:27 PM   #13
Tom
Tom's Avatar
I don't. I just use normal gas.
Old 10-07-2020, 08:01 PM   #14
72c20customcamper
72c20customcamper's Avatar
Actually normal gas is non ethonal. I use it it in everything with a carb . Newer cars with fuel injection will run with stale gas you may get a miss code but a few tanks of fresh gas it will clear
Alcohol attracts water so it contaminats the gas new cars are sealed systems for the most part. Older cars are vented so air moves in and out fresh air equals moisture .
Also if you dont have all new gas lines with low permiation ethonal resistance with new gaskets in the carb your looking for trouble. Ethonal turns old rubber and gaskets to mush
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-08-2020, 09:17 PM   #15
RUN GMC
RUN GMC's Avatar
I use this site to find where I can get it in my area and on trips(Hot Rod Power Tour and Cruising the Coast).......
https://www.pure-gas.org/
RUN GMC is offline   Reply With Quote
Old 10-04-2020, 11:51 AM   #16
LT7A
Protecting from the corrosive nature of the ethanol is the primary benefit. A small secondary benefit is a tiny bit more power. It's been a while since I did my research, but I'm pretty sure that the alcohol has about 60% of the energy of gasoline. So that 10% alcohol is only good for about 6% of the energy. So in total, the E10 gives you 96% of the energy or BTUs of E0. So hey, 4% more power, just in the gas alone. I can't easily get E0 where I live, so I run sta-bil 360 and I'm very happy with it. It stabilizes the fuel for a year and keeps the ethanol from damaging your fuel system. It also cleans your fuel system and emits a vapor to protect the areas of your tank that aren't submerged in fuel, like if it's only half full. I have no ties with the manufacturer, they haven't even sent me a hat, haha. I just did a bunch of research and found a product that helps counter the effects of the ethanol and adds a couple other benefits. I did notice that my truck ran a little better as I went through my first few tanks with the sta-bil 360. 10 oz treats 50 gal, so it's only about $0.10 a gallon, as compared to 25 or 30 cents extra for the E0 here.
Old 10-09-2020, 07:13 AM   #17
Mattchu60
I run E-15 gas in everything I own, lawnmower, trimmer, my 87 Square ran it for 8 years without issue.
I think you would want to put non ethanol in for winter storage due to the corrosive nature, but if your driving it you'd be fine running Ethanol.
Mattchu60 is offline   Reply With Quote
Old 10-15-2020, 07:30 PM   #18
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Those who made detailed posts about the harm ethanol causes to carbs are right on. And they explained why. Individually we may have a different experience, but me, living in an area with lots of rain and humidity, I run all ethanol free in my small motors. I'll run gas with ethanol in it in my carbed truck, but only in the summer.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 10-15-2020, 10:04 PM   #19
franken
Since the small engine topic has surfaced, I had trouble with mowers and weed eaters until I had the bright idea to run them out of gas at the end of the season. In the spring they'd start normally after a refill. The ethanol and water it attracts are hard on carbs.
Old 10-16-2020, 08:17 AM   #20
Corts60
Just here to tinker
Corts60's Avatar
Me too. I always run my small engines out of gas before storing.
