09-29-2020, 02:19 AM | #1 |
Smoke on acceleration - video
I’m going to do a compression check to see if it’s the rings. Once I got everything together, there was not really any smoke coming from the exhaust. However, when I blipped the throttle, smoke came from the exhaust; bluish hue. I figure the valve stems are probably ok.
And, since I’m going to have the trans out of the truck, it might be a good time to pull the motor if the rings are bad. Just checking to see if my thinking is correct on the smoke @acceleration. What do you guys think? Also, how do I determine what size rings I need for my pistons? Trying to post link to video- hope this works: https://youtu.be/sSD6IEEq-Is
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 09-29-2020 at 02:51 AM. |
09-29-2020, 06:35 AM | #2 |
Re: Smoke on acceleration - video
I watched the video, are you talking about the smoke coming from the breather? If you're getting noticeable increase in fumes/smoke from the breather as you rev. the engine, especially with no load, I'd say your due for an overhaul. Blue smoke from the exhaust means you're burning oil, but it could be from the valve guides too.
The size of rings that you need will be determined after teardown and depending on whether it needs machining. |
09-29-2020, 06:39 AM | #3 | |
1963 C20, small window, long bed 292, 4-speed |
09-29-2020, 08:27 AM | #4 |
It’s time for an LS
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
09-29-2020, 09:21 AM | #5 |
Who Changed This?
Needs rebuilding. That's blow-by coming out the breather cap- combustion gases leaking by the rings. The rings are shot.
09-29-2020, 09:26 AM | #6 |
I could cure that smoky breather in two shakes.
So could you Steve if you look closely. |
09-29-2020, 10:59 AM | #7 |
How would you do that?
09-29-2020, 03:25 PM | #8 |
Did compression check, all cylinders 155-165. Added oil to each and no increase in compression readings.
Maybe it’s just valve guides?
09-29-2020, 03:49 PM | #9 | |
Who Changed This?
Asshat- Put a PCV valve on that valve cover and connect the hose from it to the carb! That'll at least recycle the smoke. I thought you were getting smoke out the tailpipe. That accelerator pump or the circuit need a little help to get that stumble out when you speed the engine up.
09-29-2020, 04:00 PM | #10 | |
And, I am getting smoke out of the tailpipe.
09-29-2020, 04:19 PM | #11 |
Might be new but it does nothing if it’s not hooked up!
09-29-2020, 04:56 PM | #12 |
It's plain as day, it's right in the first part of the video. The hose from the manifold goes to the PCV valve.
09-29-2020, 06:01 PM | #13 |
The only hose I see of the intake goes to the steering column but if it’s smoking from the exhaust it don’t matter
10-03-2020, 03:16 PM | #14 |
10-03-2020, 06:52 PM | #15 |
Any idea how many miles are on that engine?
10-03-2020, 07:27 PM | #16 |
No idea. That is why I am pulling it.
Going to check the pistons and bearings.
10-05-2020, 05:52 PM | #17 |
Debating on whether I should just re-ring the pistons and hone the cylinders or send this off to a shop and get everything re-done.
I am inSouth Orange County CA, so there's not any shops right around me. Everything is up towards Santa Ana and Orange. Anyone have a shop they used in this area? What would you guys do if you were on a limited budget?
10-05-2020, 06:08 PM | #18 |
This is what everybody is looking at I think...when the say the pcv not hooked up
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 10-05-2020 at 06:47 PM. |
10-05-2020, 06:14 PM | #19 | |
10-05-2020, 06:47 PM | #20 |
I got ya..good luck with the rebuild...
10-05-2020, 06:59 PM | #21 |
Who Changed This?
Your primary concern for how to approach either rebuilding it or just a ring job is to assess the cylinder walls. Is there a ridge near the top where the piston rings stop going up on the stroke? Do you have some inside calipers that can reach into the bore and measure for ridge thickness and taper?
I'd like to see a piston to look at the oil control rings. Even with good compression if the oil control rings are not wiping the cylinder properly, it's still going to smoke. Do you know anyone on the board knowledgeable enough to help you with that assessment? I'd look at it but I'm about 60 miles away, and I loathe driving the 405 after about 27 years of doing that.
10-05-2020, 08:21 PM | #22 | |
10-05-2020, 08:28 PM | #23 |
There is a slight ridge at the top of the cylinder bore, about 3/8” below the block surface.
10-05-2020, 08:31 PM | #24 |
Pull the rings off one piston and check their fit and gap.
Use A feeler gauge To measure. You might find none of the rings will stay in the bore to be measured though. I’ve seen that on a 396 that burned a quart every 1oo miles. |
10-05-2020, 08:35 PM | #25 |
Calipers won't be accurate enough to measure past the cylinder ridge and on down into the bore...you'll need telescoping gauges and micrometers..or a true bore gauge...
And ditto to what geezer says...
